Blend Door issues? Here are your answers!
Old Jun 2, 2018 | 07:37 PM
  #41
Husa4342's Avatar
Originally Posted by dr_funk24
H2, 2004
change out the actuator located to the right side of the steering wheel, kind of behind the stereo area. Pay attention to how the gear wheel behind it comes off. About an hour and 80 bucks.
Old Jun 5, 2018 | 07:51 PM
  #42
dr_funk24's Avatar
thanks Husa4342, i have ordered the part and will attempt to tackle this myself, as my H2 isnt my daily driver, i can have patience doing the install. is there any instructions somewhere on how to remove the dash? to access this damn actuator
Old Aug 12, 2018 | 11:29 PM
  #43
Flip232's Avatar
Default Blend issue??
Ok my ac blows cold and the blower is blowing hard but I dont get a lot of flow out the vents, request any help.
Old Aug 13, 2018 | 10:06 PM
  #44
NoSpoon's Avatar
We need more info. Do any of the vents have good flow? What about at the windshield?
Old Aug 14, 2018 | 02:24 AM
  #45
Flip232's Avatar
Default Blend issues
No vent blows hard, all are weak flow. I can hear the flappers moving when I change the setting and they blow out correct locations. All are cold.
Old Aug 14, 2018 | 01:45 PM
  #46
NoSpoon's Avatar
Do you have a cabin air filter? It could be dirty and blocking flow. Have you checked to see that the air intake in the floor is not blocked? If the fan is running fast and the flow is not sufficient then something must be either blocking the intake or the actual flow. Good luck!
Old Aug 14, 2018 | 06:09 PM
  #47
Flip232's Avatar
Default Ac blend
Mine is a 2003 so as far as I know you have to cut the box open under passenger side to change cabin filter. Does anyone have a good way to do this?
Old Aug 14, 2018 | 07:32 PM
  #48
There is no filter. You can hack the box open to install one if you want one.
Its a bit of a pain to remove but I'd pull both wipers and remove the cowl cover. On the passenger side is the air intake and blower wheel. Mine had somehow gotten a bunch of leaves in it over the years and was starting to make noise. If the inside of the blower wheel is packed with leaves or something that would certainly reduce airflow.
Old Aug 19, 2018 | 08:38 PM
  #49
twynbyz's Avatar
I have a 2003 H2 and had air blowing out of the defrost only. I just replaced the driver side actuator and now I have air blowing through the front vents. But now the issue is that I have cool air blowing out the driver side and semi cool air blowing out the passenger side. With that said I'm going to now change the passenger side actuator located on top of the dash. The other issue I have is weak air floor through the rear back seat vents. Does anyone know what I need to check to resolve the weak air flow through the rear back seat rear vents?
Thanks in advanced for your help!
Old Oct 26, 2018 | 04:29 AM
  #50
Flip232's Avatar
I took it to dealer to diagnose....they said main blend door needs replaced. But I have to discharge the ac system first. Has anyone had to do this? The dealer wants $2400 to fix it.
