General Hummer Talk Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Under Hood Lighting
Old Dec 10, 2024 | 07:19 PM
  #21
The coolant reservoir for an Alpha has a different cold full line than the I5s, and I pointed this out to you in another thread with pictures where you tried the same chit. The level is spot on where it is. Live and learn.
After 40yrs in auto repair ASE/MT/SA/SM/SO retired, I know where the overflow should be cold (GM at the seam).
You go any lower than your current level you will be sucking air causing issues!
You need to do more research proper tank level cold.
Old Dec 11, 2024 | 10:04 AM
  #22
So you posted an online pic from somebody that has their Res overfilled in defense of your ignorant statement? What was the coolant temp at the time the pic was taken?
I had an 07, it is different than an 09 Alpha. I know where the fill line is, you do not, pretty obvious.
Looky looky at the fill line for the Alpha, way down below the mold joint all the way down at the bottom of the Res where it curves.....
Old Dec 11, 2024 | 10:10 AM
  #23
After the digression, I give the GM Underhood Light project a thumbs up.
Any of you guys done it differently, feel free to let us know.
Old Dec 11, 2024 | 12:08 PM
  #24
Picture posted from new car show review back in 2008. Arrow is absolute minimum full cold is above. Fill to tank seam is FULL COLD also allows more time when a leak develops without causing overheat condition. If you came into my shop for service coolant system would be inspected for leaks and coolant would be added. Drive on.
Old Dec 12, 2024 | 03:05 PM
  #25
Once again HUMMERS ...
Old Dec 12, 2024 | 07:09 PM
  #26
Old Dec 27, 2024 | 08:57 AM
  #27
lucky19942001
Mar 20, 2020 10:01 AM
H2Hummer
Mar 27, 2019 08:48 PM
dukie748
Jul 17, 2015 06:39 AM
Gods Gift
Jan 23, 2010 08:46 AM
Wu Jen
Jan 24, 2007 09:05 PM
