Ignition Switch???
Old 02-04-2011, 11:13 AM
InfantryH2's Avatar
Default Ignition Switch???
Wondering if u guys can help. My h2 is having some startup issues. I go turn the key to on just prior to starting it and everything is good. I go to crank it and it acts like it wants to start but then it dies. The dash lights then start to flash on and off to the cadence of the door chime and exterior lights remain on. Turn the keys to off and pull them out, put them back in and turn it to the on position just before cranking and all is well then try to crank again and the light show happens again when the engine stalls.
Can someone tell or even better show me where the starter is?
How about the fuel pump to change it out? Can I go though the interior under the rear seats?
By the way it's an 03 h2 and i currently have the steering plastics off to possibly check out the ignition switch.
Is there a way to see if the big gray fuses are blown?
I'm rather mechanically inclined just never learned how to fix or troubleshoot this issue.
Thanks in advance.
Old 02-04-2011, 11:17 AM
InfantryH2's Avatar
Also wife reported that the airbag light came on and she couldn't adjust the driver seat elevation but front back and all that worked.
What is the part I'm looking for?
1)http://www.autopartswarehouse.com/po...Qgd2FycmFudHku
Or 2) http://www.autopartswarehouse.com/po...QgMTUyNDI3NTQu
Old 02-04-2011, 06:53 PM
No more Jeeps's Avatar
Are you positive your battery is 100 percent. Mine acted a little bit like this and it was the battery on the way out. Get your battery load tested. I would talk with a mechanic or dealer before I started replacing parts.
Old 02-04-2011, 07:44 PM
InfantryH2's Avatar
Thanks for the response I will start there. Wouldn't it jump though if it were the battery? I mean I am able to charge it and work on it for a bit. It won't even turn over while connected to the charger.
Old 02-04-2011, 09:40 PM
calif phil's Avatar
I dont think either of those two pictures look like the ignition switch you need.
Old 02-04-2011, 09:44 PM
The H2 takes a very high cold cranking rate battery like 820 cold cranking amps or higher. Don't let someone sell you a battery below 800 cc amps.
Don't think your charger jumper will do that. I would at least pull the battery and get it load tested.
When mine went you would turn the key and it would try to start and then go dead and the lights would come on. Also if you do get it started a low battery or shorted cell could be triggering warning lights because of low voltage. It does not cost anything to get your battery checked and then you know you have a good starting point. The H2 needs lots of battery juice to run correct. If your battery is good then start checking out the other items you talk about.
best of luck.
Old 02-04-2011, 09:45 PM
calif phil's Avatar
I was wrong it looks like the first picture you posted.
Old 01-23-2012, 11:53 AM
emillika's Avatar
Bought the igntion switch to remedy my 04's issue... Now where the hell is the switch located? Peeking around under dash I have located it yet.
Thanks.
Eddie 70
01-20-2021 10:19 AM
xmmvx74
11-19-2015 08:08 PM
cummins5390
06-03-2014 12:13 PM
John Maddox
04-21-2012 07:01 PM
BLUETHUNDER
05-01-2010 07:23 PM
Quick Reply: Ignition Switch???
