06' H3 noise in front end HELP!!!
Old Jan 22, 2012 | 12:17 PM
MATYLDASMOM's Avatar
Default 06' H3 noise in front end HELP!!!
When I make a sharp turn I have a loud clunk in my right front tire?? Also while stopped if you turn the wheel all the way to either side and take your foot off the brake it doesn't move almost like it's binding up. I have no problems just driving down the road. On snowy roads it doesn't have the clunk when turning. It's a 2006 H3 with 60,000 miles. Any ideas what it could be..
Old Jan 22, 2012 | 03:53 PM
Hello and Welcome.
Upper or lower ball joint, outer tie-rod, Hub bearing.......
Old Jan 22, 2012 | 06:55 PM
RKSmith163's Avatar
You may be in HI Lock either by accident, stuck switch or damaged fork in transfer case. Those would be my first checks.
Old Jan 23, 2012 | 11:25 AM
Default Thanks you guys
Funny you should say a stuck switch. The first time it happened, I noticed I was locked in 4H luckily I live on dirt roads and was only going 10-15mph, I put it back where it should be and 20 min. later took a sharp turn heard the noise and now it happens ebrytime I make a sharp turn..So now the question is how do I get it unstuck???
Old Jan 23, 2012 | 12:34 PM
RKSmith163's Avatar
If you are not binding at very low speed on dry pavement, then it is likely something other than being stuck in Hi Lock or a bad fork. Exercise the switches and see if that helps. Could be a CV joint going bad or a number of other things such as Tainter mentioned.
kramcard6
Jan 25, 2015 01:49 PM
lx93racer
Aug 21, 2011 08:14 AM
jen813
Apr 12, 2006 06:07 PM
usmcman001
Feb 9, 2006 12:06 PM
falcons28fan
Jan 18, 2006 10:29 PM
