WARRANTY WORK
Old Feb 20, 2006 | 11:16 AM
hummerific's Avatar
Default RE: WARRANTY WORK
At 5900 lbs I am assuming they will wear out pretty fast depending on how fast you drive and how much city you do
The h3 is 4700 lbs. right?
Old Feb 20, 2006 | 02:17 PM
Rayvyn's Avatar
No... 5900 Gross...
Old Feb 20, 2006 | 02:29 PM
hummerific's Avatar
Thats ridiculous, why is it so much heavier than they say it is.
Fuel should only make it about 200 lbs. heavier or less.
Old Feb 20, 2006 | 02:36 PM
Dennis's Avatar
ORIGINAL: Rayvyn
No... 5900 Gross...
Close enough.. But if you back out the Payload capacity you're at 4700lbs all by itself...Just keep the fat mammas out and you'll do better on the MPGs...[sm=smiley30.gif]
But I also understand that the DriveTrain is up to Mil-specs standards and quite durable [Standard transfer case is 2.64:1 (Borg Warner 4493), Adventure Series or (Off-road package) has a 4:1 transfer case (BW 4494)]...Not something you'll find in a typical pickup or passenger car..so I think it will hold up under the long haul just fine.
Old Feb 21, 2006 | 06:21 AM
Rayvyn's Avatar
Gross means fuel, friends and cargo... Loaded it is 5900 lbs but vehicles have to be designed for that level of operation and not the lightest possible loads... Regardless of how you measure it however, it is the heaviest vehicle in its class and almost the lowest power rating so it is only reasonable to assume there is a high likelihood of problems and in that, the transmission and brakes are the most likely place for this to occur... I like it as little as anyone else but I will watch them both closely and I think everyone else should too...
Old Feb 21, 2006 | 06:30 AM
Rayvyn's Avatar
ORIGINAL: Dennis
ORIGINAL: Rayvyn
No... 5900 Gross...
What milspec is on the tranny?? I'd agree the diffs and tranfer cases are fine but who is confident about transmissions required to compensate for this level of imbalance?? As far as I know, no transmission has ever been asked to do this task before so who can say what will happen?? I want it to as much as anyone but GM set out to make this much more powerful and failed to come thru so the system is not targeted at the H3 nor is it even GM's first choice... Combined it will keep we watching very, very closely...
Old Feb 21, 2006 | 03:47 PM
Dennis's Avatar
[quote]ORIGINAL: Rayvyn
ORIGINAL: Dennis
ORIGINAL: Rayvyn
No... 5900 Gross...
You're so right..worth keeping an eye on...In the meantime, I'm going to enjoy the H3 with no worries..Or at least until the warranty expires.
Old Feb 23, 2006 | 11:58 AM
Rayvyn's Avatar
Don't worry... The average life of a tranny has got to be somewhere between 150000 - 200000 miles so even if this one is stressed, it should make it to at least 50000-150000... You can bet GM made sure they could make the 40000 warranty mark however... They arn't stupid and that being probably their only concern and/or requirement, I'd bet they made it good enough for their needs...
Old Feb 23, 2006 | 01:15 PM
dilo2001gt's Avatar
I had a Blazer to small of motor for the trany i had 7 of them replaced soon as one problem with this H3 GOOD BYE HELLO TOYOTA
Old Feb 23, 2006 | 08:02 PM
G Man's Avatar
According to my paperwork, the H3 has a 4 year 50,000 mile warranty b to b.
wixomhead
Apr 14, 2011 07:38 PM
sharphummer
Jul 23, 2009 08:52 PM
investr
Dec 28, 2008 09:32 AM
Champ53
Aug 3, 2006 09:01 AM
flexline
Apr 7, 2006 01:22 AM
