relube t case
Old Jul 7, 2015 | 09:31 PM
happythree's Avatar
Default relube t case
what a mess!! i drained just one qt, not 1.5 and no sign of leakege. book says 1.5 qt.
i finally ran a tubing from the fill hole across the cross member and held the tubing on a nipple on a qt bottle. i used almost 2 qt with all the messy leakage till it overflowed and pluggedi up.
can anyone verify the fill hole is about even with the cross member. i thought it was higher??
Old Jul 8, 2015 | 06:30 AM
What year?
Old Jul 8, 2015 | 10:21 AM
norinco3264's Avatar
My 2006 requires removal of the speed sensor and add .25L thru that.(you can see the sticker instructions that they added). I haven't changed the fluid since I've owned it, but I'm planning to do it this week. Seems like there's lots of mixed feelings about what fluid to use.
EDIT= What fluid do you recommend?
File Type: jpg
Old Jul 8, 2015 | 11:40 AM
Use whatever the Owner's Manual in your glove box says to use.
Old Jul 8, 2015 | 01:33 PM
Figured you'd say as much. Manual calls for Dex3. Isn't in production anymore.
Some stealerships and autozone's database calls for Dex VI.
If you take a stroll through the other hummer forums, you'll find even more mixed opinions:
"Manual Transmission fluid p/n #888861800 is currently available through GMSPO. Current and past model vehicles listed above (Models 2007 Hummer H3 and prior) with either a Manual Transmission or Transfer Case that required Dexron III should use the Manual Transmission and Transfer case fluid #88861800. This fluid is a direct replacement for Dexron III used in manual transmissions and transfer cases. DO NOT use Dexron VI in place of the #88861800 fluid in any manual transmission or transfer cases as a failure may result"
I didn't ask what the manual calls for, I asked what he recommended. Royal purple, redline, manual trans fluid, dex6, etc.
Old Jul 8, 2015 | 09:44 PM
happythree's Avatar
oops,,,its a 2010 with 56000.
the fill hole just looked low, like midway down.
oh, my book says dex 6, its red. the old stuff was black,used.
Old Jul 11, 2015 | 12:25 AM
bobbarker14's Avatar
Im using Royal Purple Synchromax manual transmission fluid #01512. It is a direct replacement for the GM #88861800 according to Royal Purples lubricant cross reference chart. http://www.royalpurpleconsumer.com/a..._Reference.pdf
Running beautifully after 9k miles.
Old Jul 11, 2015 | 12:27 AM
Forgot to add - 2007 base model. GM part number taken directly from owners manual.
ride450
Jun 26, 2021 02:00 PM
weaponsgalore
Apr 14, 2007 07:04 PM
midnight94r
Mar 16, 2007 12:44 PM
howdy301
Jan 23, 2007 09:19 PM
Jul 19, 2006 03:05 PM
