PROBABLE DIFF BREAK...
Old Jan 2, 2008 | 12:19 AM
  #31
NOMOYELLO's Avatar
Default RE: PROBABLE DIFF BREAK...
2 BTM OR NOT 2 BTM. That is the ???????????
Old Jan 2, 2008 | 12:24 AM
  #32
I use BTM with the H1s butseldom did with the H2. Haven't really tortured the H3 yet. That is one of the good things about the forums...you can learn from those that are wiser and dumber and more and less experienced than you without having to suffer the same pain.
Old Jan 2, 2008 | 12:28 AM
  #33
NOMOYELLO's Avatar
ORIGINAL: 3hummers
AMEN!
Old Jan 2, 2008 | 01:10 AM
  #34
Sewie's Avatar
ORIGINAL: importkiller
he explained that the TC cannot be turned off but the stabil can....at least I am pretty certain of it. But my memory does suck...maybe he can stop by here and read this? Prolly not
You and F5 are correct. The manual incorrectly states that the TC can be turned off.
BTW, I've been on the White Rock trail at Hollister. My locker wasn't working at the time and I had to turn around. The XJ I was following that was open/open walked it with no problem. The trail is uphill, with lots of mogels, and very loose. With IFS and no locker, its damn difficult. Solid axles make a difference on that trail.
Old Jan 2, 2008 | 01:19 AM
  #35
Sewie's Avatar
Hey NOMO, I know that sound all too well. [:@][:@]This was #3 of my busted diffs. I had the dealership replace the housing with the Alpha's cast iron one. Hopefully that will reduce the chances of #4.
[IMG]local://upfiles/482/90A349E155994ED79D4F4843A23B06D7.jpg[/IMG]
[IMG]local://upfiles/482/14A4E3AEAFCE4EA0BC7AD8308D430256.jpg[/IMG]
[IMG]local://upfiles/482/DA275C00E6D34594BCAC8E8FDC3C56F4.jpg[/IMG]
Old Jan 2, 2008 | 07:10 AM
  #36
HummerGuy's Avatar
I have an '06 Manual as ImportKiller and some of you were talking about. IK is right. The Manual does NOT have StabiliTrak, but was offered as an option in the '07 and '08 manual transmissions, but not in the '06. The only way to get it was to spend the $1895 extra to upgrade to the Automatic, in which it is a standard feature that the upgrade.
Anyway, if Traction Control can NOT be turned off, then what does the H3 do when you press the button to turn it off and the display says TCS OFF or Traction Off? What is it turning off? Is it just toning down how much it is used? Why put the button/feature on the dash to turn the system off if it doesn't turn off?
Hopefully somebody knows and can explain.
Old Jan 2, 2008 | 10:09 AM
  #37
tomp's Avatar
Maybe is just allows for more wheel spin (in which would be even more harmful to the front diff as RPMs would be higher when it activated) similar to the TC2 mode of the H2.
Old Jan 2, 2008 | 10:12 AM
  #38
sewie, remind me not to loan you one of my trucks.
Old Jan 2, 2008 | 12:23 PM
  #39
NOMOYELLO's Avatar
As far as WHITE ROCK .It is 2 trails the right trail consist of a frame twister solid white rockand covered with crushed rock(HANDLED IT BUT NOT AS WELL AS DAVES WRANGLER UNLIMITED). After that you can go right or straight.I went straight up the hill with tons of loose white rock and dirt and a pretty big boulder on the left halfway up.As I get closer to the boulder the dirt and rocks became loose and deep.Fearing That I would smack the boulder because of slippage.I back down.And the jeep and I make the call 2 go around.I go 2 my left and the choices were anotherLEFT down the hill or RIGHT up the hill.I stopped and the jeep and I decided 2 take the hill.This hill consisted of loose white rock of various sizes lots of loose dirt and a pretty big rut.NO BOULDER. I stepped aside 2 let the man go through.He crawled it.I was like a driving through bacon grease.
Old Jan 2, 2008 | 12:25 PM
  #40
NOMOYELLO's Avatar
How much extra was the ALPHA FRONT DIFF??????
