Moon roof
You might be able to assist it opening and closing but there is a risk that it could get jammed and stuck open. On mine, it will open but I have to push it forward pretty hard with one hand while holding the button to close it. Tilt works fine though. Probably the only other way to get at the drains will be to drop the headliner around it, then you could pull the tubes off and clean them that way.
MixManSC - mine is the same, Open-OK, Close- Hand Assist, Tilt-OK
Unfortunately the dealer I bought my truck from oiled the slides - bad idea, only made things worse!
PTFE spray might be better or the lithium grease spray as suggested by bronxteck.
Wfive
Apr 20, 2016 01:12 PM
ghettoct
Aug 14, 2007 01:39 PM
khelms_98
Dec 25, 2006 04:38 PM
