Moon roof
Old Apr 23, 2019 | 10:55 AM
Paula Reeves's Avatar
Default Moon roof
05 h2 hummer. Moon roof leak. Now wants to open but doesnt. Seems stuck. Any other way to open to clean out drain holes....???
Old Apr 23, 2019 | 12:03 PM
You might be able to assist it opening and closing but there is a risk that it could get jammed and stuck open. On mine, it will open but I have to push it forward pretty hard with one hand while holding the button to close it. Tilt works fine though. Probably the only other way to get at the drains will be to drop the headliner around it, then you could pull the tubes off and clean them that way.
Old Apr 23, 2019 | 10:11 PM
mine was running a bit slow and I cleaned and greased the tracks with white lithium grease spray. it helped a lot.
Old Apr 24, 2019 | 03:27 AM
oceanbrave's Avatar
MixManSC - mine is the same, Open-OK, Close- Hand Assist, Tilt-OK
Unfortunately the dealer I bought my truck from oiled the slides - bad idea, only made things worse!
PTFE spray might be better or the lithium grease spray as suggested by bronxteck.
Old Apr 24, 2019 | 10:06 AM
Agreed - most white lithium grease, when in an outdoorish environment tends to get thick and stiff over time.
Wfive
Apr 20, 2016 01:12 PM
Intercooled
20
Jun 12, 2008 12:44 AM
ghettoct
Aug 14, 2007 01:39 PM
MRDM1
27
May 31, 2007 07:49 PM
khelms_98
Dec 25, 2006 04:38 PM
