Increase clearance between CAI and coil pack
Old Mar 30, 2011 | 06:22 PM
Widespread Hummer's Avatar
Default Increase clearance between CAI and coil pack
A number of people with the Spectre style intake have noted the lack of clearance between the coil pack and straight pipe. While looking at mine today, I looked a little farther down the system and found that by raising the forward "foot" of the filter box it lifts the CAI enough to take the pressure off the coil pack. I grabbed the nearest thing I could use as a wedge, which happened to be a golf tee, that you can see in the picture below. Tomorrow I am going to figure out a proper bushing to put under the rubber bushing in place on the mounting bracket. Hope this helps a few.
Attached Thumbnails Increase clearance between CAI and coil pack-img01851-20110330-1414.jpg
Old Mar 30, 2011 | 06:31 PM
wfturner's Avatar
The DocOlds CAI has a small dimple to clear the coil pack. You may want to try that rather than move your air box, your choice.
Old Mar 31, 2011 | 03:54 AM
Ideally, I should have just bought the AIRDOC but what I am dealing with is ABS, so I am only going to know I've gone too far once I've gone too far. I could patch if it went through but i'd rather not. What I did will only raise the box about 1/4" at the mounting point which translates to about 1 mm of movement of the CAI overall. I will have to make sure that doesn't cause a fitment issue at the rubber boots, but I think it should be fine. It really is only relieving the pressure on the coil pack from the straight tube to eliminate any rubbing.
Old Mar 31, 2011 | 07:33 AM
wfturner's Avatar
If you have a heat gun you could dimple the ABS where the coil pack meets the tube.
Tricky but possible
Good luck, it sounds like you have it figured out
jayhawkhummer
Aug 28, 2009 08:06 AM
NJTEX
Nov 14, 2007 10:05 PM
HummerGuy
Mar 16, 2007 01:03 AM
jdrew
Jan 29, 2007 04:25 PM
HummerGuy
17
Nov 22, 2006 02:28 AM
