"flashing red lite"
Old Oct 8, 2010 | 04:25 PM
Broken Halo's Avatar
Originally Posted by Pauldy
have you checked the voltage broken? Very few LEDs operate at 12V and I can't recall ever seeing a surface mount at 12V. I'd bet the voltage on that board is around 3-5V.
That's why you use the 1k resistor in series. It brings the voltage to a safe level
Old Oct 8, 2010 | 05:54 PM
Pauldy's Avatar
I see your point about the current limiter but I would still be worried about the 914s forward operating current I'm pretty sure at 1k your pretty close to the ceiling at 12V no?
Old Oct 8, 2010 | 06:40 PM
drtom's Avatar
Banned
Default pls reread previous posts
ive mentioned stuff you are asking about.
read slowly and think.
im a poor typist so i get frust,,,
i never measured the volts!,,they used 680 ohms for their leds. i used 2, 820 or 1000 ohm .
2x1000 =2000!!.
thats less than 6 ma.at 12v so dont sweat the small stuff that i have already been using since last july 2009!!!
if you did blow a part the total list is apx 5 bucks!!
so worry about the MECHANICALS that i mentioned on page 1!!!
the parts work
if u reread you will find mention of possible use of wires on the plug for the board,,that i did not explore.
kiss,,means keep it simple xxxxxx
tom
Old Oct 8, 2010 | 06:56 PM
You could be right.....I'm good at 12 volt vehicle wiring, but I only know enough about electronic circuitry to be dangerous. That's why I've been checking everything with drtom, but I think I've used my quota. The flashing led I'm looking at is a Radio Shack model #276-036, which requires 2.25 volts typ., 2.6 volts max. at 90ma forward voltage, which calculates to a 150ohm 1.2 watt resistor. I don't know how to determine if that will or will not work with the 914 blocking diode.
Old Oct 8, 2010 | 10:52 PM
drtom's Avatar
Banned
Default trust me
same led im using as shown in cheap drawing,about 6-10ma, its bright
ifn u run 90 ma it will hurt ure eyes and melt sooner
the wheel has been invented , it rolls,no need for further invention,,,,,EXCEPT IN MECHANICAL AS MENTIONED IN FIRST LINE!!!
you can find better ways to connect,and place components
bendyprissy
Feb 22, 2013 05:15 PM
jng1226
Feb 16, 2010 09:01 PM
drtom
Jan 2, 2010 11:50 AM
harbormaster
Jan 17, 2008 05:36 PM
JeepeaterH3
Sep 10, 2007 07:14 PM
