Cutting fender for access to thermostat?
Old Jan 13, 2018 | 09:50 AM
JerseyCoast's Avatar
Default Cutting fender for access to thermostat?
2007 H3....Ok so I was a total idiot by taking this on. They placed this thing in the worst possible spot. Trying to get new one back in and fender wall is cutting me up pretty good.
Wheel is off, fender well is out, I'm talking about cutting the actual fender panel that extends down towards wheel. Thinking about making a cut and bending up an area, so that I can access it easier. I just can't fit in the space now, tired of bleeding lol.
Thoughts? Would be a small area, nothing major. Always like to ask here, good group of guys.
Old Jan 13, 2018 | 10:16 AM
Looking to take an inch or two off bottom to get access back to thermostat. Right abt where the hose is.....
Old Jan 13, 2018 | 10:57 AM
Universal joint socket and extension to remove/tighten upper bolt. Pita, I know. I've also seen some remove the alternator to access the upper bolt(a lot more work than necessary). When installing the new thermostat, without the hose connected, and make sure housing is right side up. Tighten bolts and reinstall the hose(new gear drive clamps are recommended).
Cutting the fender is not a good idea. GL
Old Jan 13, 2018 | 12:05 PM
BruceS's Avatar
Long extension on 1/4 drive with 10mm.
I gutted the thermostat and reinstalled housing. Then I shortened the housing on top radiator hose at head. Get inline thermostat housing and install thermostat up top. Much easier to change out later. I ran a 180 thermostat in summer and 190 in winter.
Attached Thumbnails Cutting fender for access to thermostat?-6872e6b1-a245-424d-baa1-decb749898ce.jpeg   Cutting fender for access to thermostat?-d51c7640-d427-466f-b2b7-e5725b0635e5.jpeg   Cutting fender for access to thermostat?-981ee961-16da-4519-9029-100764151b9c.jpeg   Cutting fender for access to thermostat?-284d1933-0525-4a08-8998-f3bad6238c98.jpeg
Old Jan 13, 2018 | 01:03 PM
happythree's Avatar
i had to move my door key lock to a new door. couldnt see how to get at it. cut 3 sides of a hole on inside panel and bent it away. bent it back later. no harm done.
Old Jan 13, 2018 | 01:46 PM
that is different, you did not cut into a panel that supports weight and exposed to the elements. Cutting a fender pinch weld will cause structure failure over time.
Old Jan 13, 2018 | 06:26 PM
Stayed with it and got it done without cutting. As much as it would be easier, I was afraid to do it, chickened out.
I like the idea above shortening the hose and all. Keeping that one in my pocket for next time.
Thx for the info guys!! Always appreciated!!
Old Jan 13, 2018 | 07:12 PM
happythree's Avatar
i was "just saying"!! in this weather i didnt look under at it,,,but i assume it could be bolted solid with decent metal later if worried huh?, or, dont cut it!
rwheeler54
Apr 3, 2011 12:55 AM
HummerGuy
17
May 5, 2008 11:04 AM
buddy
16
Dec 11, 2006 01:17 PM
archer
Mar 8, 2006 10:32 AM
