chirp when turning slow
HI every1 ... My H2 had a high pitched chirp when turning , most on reverse . Only thing I found was the ball joint damage ( which I got to replace anyway)
I did lubricated the joints and the chirp stop for a day or two then came back worse
Is this relate to the joints or Any thought what could this chirp be ?
Also what would be your recommendation for replacing the ball joint (only the bad part or all the front end )
Any specific brand or OEM parts ?
Truck had only 70,000 miles , no offroad .
Ball joints, tie rod ends, idler?Pitman arm and control arms I use Moog. Its not because they are any better or worse but because they have a Lifetime warranty and are serviceable. when I say serviceable I mean they have zerk fittings in them so that you can actually lube all the moving joints with a grease gun. Most Oil change places used to do this but its starting to go away as more and more cars have sealed joints.
everytime I have a prob with the front suspension I get a whole new part for free.
The moogs wear out just as often as the stock parts but I don't have to pay for them again.
The BJ is good for now however the rubber boots are all cracked .. Is this fixable or do I need to replace the whole part . Thanks
Kowaiter
24
May 21, 2019 12:23 PM
JCsh2
May 5, 2013 09:24 AM
Indyone
Apr 29, 2013 06:07 PM
SedonaBoundH3
Apr 11, 2012 02:08 PM
