chirp when turning slow
Old Nov 10, 2013 | 10:10 PM
H2Miami's Avatar
Default chirp when turning slow
HI every1 ... My H2 had a high pitched chirp when turning , most on reverse . Only thing I found was the ball joint damage ( which I got to replace anyway)
I did lubricated the joints and the chirp stop for a day or two then came back worse
Is this relate to the joints or Any thought what could this chirp be ?
Also what would be your recommendation for replacing the ball joint (only the bad part or all the front end )
Any specific brand or OEM parts ?
Truck had only 70,000 miles , no offroad .
Old Nov 12, 2013 | 01:38 PM
H2CANEPADESIGN's Avatar
Ball joints, tie rod ends, idler?Pitman arm and control arms I use Moog. Its not because they are any better or worse but because they have a Lifetime warranty and are serviceable. when I say serviceable I mean they have zerk fittings in them so that you can actually lube all the moving joints with a grease gun. Most Oil change places used to do this but its starting to go away as more and more cars have sealed joints.
everytime I have a prob with the front suspension I get a whole new part for free.
The moogs wear out just as often as the stock parts but I don't have to pay for them again.
Old Nov 13, 2013 | 07:15 AM
H2Miami's Avatar
Good info ... I was planning to get Moog as everywhere recommended .. However the real problem was found with the Hub as you read on early thread
The BJ is good for now however the rubber boots are all cracked .. Is this fixable or do I need to replace the whole part . Thanks
Kowaiter
24
May 21, 2019 12:23 PM
JCsh2
May 5, 2013 09:24 AM
Indyone
Apr 29, 2013 06:07 PM
SedonaBoundH3
Apr 11, 2012 02:08 PM
TOYBOX
Jul 28, 2010 04:37 PM
