brakes problems/4x4 problems
Old Feb 21, 2018 | 04:59 PM
NFS's Avatar
NFS
Default brakes problems/4x4 problems
hey folks, one last problem I had and I been looking for a solution online but no luck.
1- there are 3 4x4 options one that is standard and then one that have a lock logo with arrow up and arrow down.
my 3rd one with 4x4 lock arrow down when I press on it. it flashes few times and it goes away and doesn't let me select it, what causes this???
2- if I choose any 4x4 options. I notice that sometimes when I brake. the brakes are delayed like I press on the brake pedal and then after few seconds the braking happen. its not instant like it suppose to be. what might be the problem??
thanks a lot guys for helping me out. I been fixing the hummer to get it back to go again.
Old Feb 21, 2018 | 07:37 PM
RKSmith163's Avatar
The one with the down arrow is your 4 Low. It can only be engaged when your transmission is in neutral and works best when rolling 3 or 4 miles per hour. The brake issue is unrelated. I suggest you read your Owners Manual. If you don't have one, it can be downloaded at Hummer.com
Old Feb 22, 2018 | 06:19 PM
NFS's Avatar
NFS
Thank you for explaining to me about the 4 low. its working good. I tried looking in the manual for the delay brakes but didn't find anything.. any suggestions?
Old Feb 23, 2018 | 10:13 AM
Fluid level, slide pins rusted, bad caliper, water in the fluid, etc.
Old Feb 23, 2018 | 03:35 PM
NFS's Avatar
NFS
But I did brake fluid flush and it still happens, how to find out if it’s rusted pins? And what are the pins? What about the bad caliper? How would I know ?!
Old Feb 23, 2018 | 08:30 PM
The pins allow the brake pads to move back and forth. If you have changed pads you had to remove the pins.
Old Feb 23, 2018 | 08:51 PM
NFS's Avatar
NFS
And what about the caliper? How do you know if it’s bad ?
BrianDye
Mar 4, 2014 09:35 AM
MeBelovinMyH3
Nov 3, 2012 08:58 AM
DZLROKET
Feb 8, 2010 04:13 PM
jbugharrison
Sep 3, 2009 01:15 AM
daddysgirl
Mar 22, 2006 11:00 AM
