brakes problems/4x4 problems
hey folks, one last problem I had and I been looking for a solution online but no luck.
1- there are 3 4x4 options one that is standard and then one that have a lock logo with arrow up and arrow down. my 3rd one with 4x4 lock arrow down when I press on it. it flashes few times and it goes away and doesn't let me select it, what causes this??? 2- if I choose any 4x4 options. I notice that sometimes when I brake. the brakes are delayed like I press on the brake pedal and then after few seconds the braking happen. its not instant like it suppose to be. what might be the problem?? thanks a lot guys for helping me out. I been fixing the hummer to get it back to go again. |
The one with the down arrow is your 4 Low. It can only be engaged when your transmission is in neutral and works best when rolling 3 or 4 miles per hour. The brake issue is unrelated. I suggest you read your Owners Manual. If you don't have one, it can be downloaded at Hummer.com
Thank you for explaining to me about the 4 low. its working good. I tried looking in the manual for the delay brakes but didn't find anything.. any suggestions?
Fluid level, slide pins rusted, bad caliper, water in the fluid, etc.
Originally Posted by TAINTER
(Post 350349)
The pins allow the brake pads to move back and forth. If you have changed pads you had to remove the pins.
And what about the caliper? How do you know if it’s bad ? |
