Badlands Park - Attica, IN - APRIL 29TH, Sunday
Old Mar 21, 2007 | 04:38 PM
  #121
jdrew's Avatar
Default RE: Badlands - Attica, IN - March 25th, Sunday
ORIGINAL: HummerGuy
Man I'm in the middle of a botched up closing/re-fi,
ewwwwwww
Old Mar 21, 2007 | 04:39 PM
  #122
ZYNE's Avatar
LOL, thanks for bailing me out on that one JD ... I was not about to try to explain squelch .. I guess I would say it limits the signal spectrum to only the stronger signals/low static ...
And if you get stuck in a pit I don't think you need a radio for us to hear you hehehehhehee ... :-)
Old Mar 21, 2007 | 04:50 PM
  #123
jdrew's Avatar
ORIGINAL: ZYNE
I will give you lotion for it to put on its skin if you are in a pit. It does what its told, or it gets the hose.
Old Mar 21, 2007 | 05:02 PM
  #124
littlehummerboy's Avatar
ORIGINAL: jdrew
What is this? Silence of the Hams?
Old Mar 21, 2007 | 05:05 PM
  #125
HummerGuy's Avatar
Yeah uh, I just uh, had something come up and I won't be able to make it sorry. In fact, I'm closing my account on here right now. uh yeah..
I just put it to Channel 9 and said "Danger, Will Robinson, Danger" and apparently they didn't like that too much...............
Old Mar 21, 2007 | 05:09 PM
  #126
shortbus's Avatar
ORIGINAL: HummerGuy
OK I got my CB, the same one Nick has. I have no idea how to use it. There are all kinds of things I know nothing about on here, like ST, CB/WX (I'm assuming that switches to NOAA) CH9/19 (what channels are those for) and I know what Scan does. What the helldoes theSquelch **** do? Does that adjust how loud my screams are when I get stuck in a pit of quick sand
the squelch, as jd mentions, determines how well your cb receives. it's basically setting the sensitivity on your receiver, so when you hear noise it means that you're picking up everything from sunspots to dogfarts. back it off just to the point where the static goes away and you should have some good range. they're very susceptible to interference, especially power lines. the receive filters are pretty wide open to accomodate the wider channel range on newer ones (ch 1-40), so they let in just about anything. as long as you're close to line of sight with each other, you should be fine even if you don't have an external antenna. if you're going to do this a lot, i'd recommend an antenna on the roof, mag-mount or permanent. that will increase your range substantially.
Old Mar 21, 2007 | 05:10 PM
  #127
shortbus's Avatar
HG's working his way up to a cavity search by the local law . . . . way to go Mary . . . . .
Old Mar 21, 2007 | 05:16 PM
  #128
ZYNE's Avatar
Better him than me Shorty, better him than me!!!!!! And yes, definitely a good call on the external antenna. I've played around with mine enough to realize I probably need to just go ahead and get one .. wish I would've gotten one while I ordered my CB but hind sight is always 20-20 they say ... ohh well ... at least they only run about 30 bucks.
Old Mar 21, 2007 | 05:32 PM
  #129
shortbus's Avatar
go with a mag mount if you're not going to use it much, and put it in the center of your roof. put some canvas between the magnet and the roof to keep it from scratching. the monster size roof will give you an excellent ground-plane.
Old Mar 21, 2007 | 05:42 PM
  #130
ZYNE's Avatar
That's what I was thinking ... though I intend to go with the Gobi Stealthrack here sometime this spring (hopefully) ... have you had any issues with it on yours!?
