AC control knob problem
Old Dec 14, 2014 | 11:00 AM
federicoiz's Avatar
Default AC control **** problem
Hi guys, I need help. The AC of my Hummer H3 3.7 is working well but when I push the button of the control **** to switch off the Air Conditioning, the light turns off but the Air Conditioning continues to work. Then to turn off the AC the only way I have is to put the control **** on position 0. Any idea? What should I do? Change the control ****? The relay?
Old Dec 14, 2014 | 11:31 AM
wfturner's Avatar
First thing to try is a basic reset, after that . . .
Old Dec 19, 2014 | 12:35 AM
andresinibus's Avatar
Is your recirculating button/light off in mine if the A/C button/light are off but the recirculating light/button are on the A/C still works Idk why but for it to b off off with just the blower working both of those have to be off good luck I'll try the procedure above as on mine the temperature dial it's not working if I go to all the way cold it's cold but if I move it just one little click over to the hot it goes all the way to hot there is no actual temp mix control
Old Dec 20, 2014 | 06:50 PM
Well did the reset and no change it only blows cold air all the way on the left if I even move one click towards the hot side it goes all the way to hot there is no medium temperature either all cold or all hot any ideas?
Old Jan 25, 2015 | 12:08 PM
federicoiz's Avatar
Hi guys, I did the basic reset and now it's working. Thanks so much.
Old Jan 25, 2015 | 03:28 PM
wfturner's Avatar
Good, stay cool, pun intended
Cube
May 10, 2012 06:41 PM
Bobb
Jan 24, 2012 04:15 PM
user 0013769729713
Mar 1, 2010 02:58 PM
civilengineerh3
Apr 23, 2009 02:25 PM
Danster
Mar 15, 2009 07:18 PM
