AC control knob problem
Hi guys, I need help. The AC of my Hummer H3 3.7 is working well but when I push the button of the control knob to switch off the Air Conditioning, the light turns off but the Air Conditioning continues to work. Then to turn off the AC the only way I have is to put the control knob on position 0. Any idea? What should I do? Change the control knob? The relay?
Thanks |
1 Attachment(s)
First thing to try is a basic reset, after that . . .
Is your recirculating button/light off in mine if the A/C button/light are off but the recirculating light/button are on the A/C still works Idk why but for it to b off off with just the blower working both of those have to be off good luck I'll try the procedure above as on mine the temperature dial it's not working if I go to all the way cold it's cold but if I move it just one little click over to the hot it goes all the way to hot there is no actual temp mix control
Well did the reset and no change it only blows cold air all the way on the left if I even move one click towards the hot side it goes all the way to hot there is no medium temperature either all cold or all hot any ideas?
Originally Posted by wfturner
(Post 320557)
Hi guys, I did the basic reset and now it's working. Thanks so much. |
Originally Posted by federicoiz
(Post 322150)
