2006 H3 funky door problems
I have a 2006 H3. All of a sudden the drivers electric window doesnt work, the door lock doesnt work, the key fob doesn't lock or unlock the doors..but it does set the alarm. any suggestions?? thx
Still have the crappy azzed factory Battery Terminal Connectors????? If so, hack them off ASAP and replace with a quality aftermarket set like Stingers or your favorite brand. This is THE FIRST mod every H3/H3T should have done!
What you describe is what happens when your PCM looses proper voltage because of a poor connection to the battery, or after the battery goes dead.
There are some long rambling threads on your issues here. Disconnect the battery, wait 15 seconds or more, reconnect the ground first, then positive, see what happens. Your Fobs may need to be re-programmed at the dealer once they loose the handshake to the truck.
Did you recently have your battery disconnected?
ski.dive
Aug 23, 2019 06:49 AM
Zeppelin
Sep 29, 2018 09:47 AM
