Newly installed AC Delco CV's busted same day
Old May 25, 2023 | 10:38 PM
does the rancho lift kit compensate for the axel angel by dropping the diff to set proper geometry? if not you probably need custom axles or the diff needs lowering.
Old May 25, 2023 | 10:44 PM
Clifford_H3T's Avatar
This is a pretty normal angle, no? Thanks for the reply.
Old May 26, 2023 | 11:01 AM
no the angel does not look aggressive at all
Old May 26, 2023 | 11:06 AM
I'm starting to think I have more serious issues going on with this truck. I've only had it a coupe of months so everything is a mystery. Something has to be bent up front, bad mounts or something putting extra stress on the axles. I noticed old dry grease splatter on both sides when I first got it but didn't think much of it. Maybe this is why it had cheap/used mismatched axles when I got it. Probably just swapped out to get rid of it.
Old May 26, 2023 | 12:56 PM
try contacting rancho they might have a better idea of what you need to look for or maybe some specs you can measure to compare wtf is going on.
https://www.gorancho.com/contact/
Old May 26, 2023 | 01:00 PM
Update: Cleaned up the area to see where the actual leak is coming from. Does this look like a bad install, bad part, or stress on the axle from the unknown?
Old May 26, 2023 | 01:34 PM
Red Bluff's Avatar
Just my 2 cents almost looks like you took a point hit to the bellows/band.
Old May 26, 2023 | 02:08 PM
I think you're right, they didn't install the bump stop that was missing and I do remember going over a few bumps that probably flexed the suspension just enough to hit a bolt or something.
Old May 26, 2023 | 03:36 PM
maybe they used a crowbar and hammer to knock the axel into or out of the hub and it slipped off tearing the boot.
Old May 26, 2023 | 05:05 PM
atvspeed4's Avatar
Agreed that definitely looks like install error
HeLP
Sep 1, 2022 03:31 PM
joefromnj
Jun 20, 2022 04:23 PM
Sirina2
Mar 27, 2020 07:27 PM
jsbihn
Jun 16, 2015 08:58 AM
zx1100
May 25, 2007 10:44 PM
