My T isn't cranking
Old Sep 9, 2023 | 05:10 PM
he did not ask you to swap a fuse. he stated relays. relays are mechanicel switches that can fail intermittently. a new fuse only has 2 phases it is either good or blown. not accounting for bad connections to it.
if some one is taking the time to respond to YOUR issues the least you can do is ACTUALLY READ what info they are suggesting to you. the devil is in the details!
Old Sep 9, 2023 | 05:26 PM
Originally Posted by echopark
not so far. The electrical issue isn’t permanent so if I swap fuses I won’t be able to tell if anything changes because currently everything is working as it should (I think). Let me know what to look for when swapped
either way I’ll swap it shortly and report back.
A week ago I went to start the hummer and it didn't start--no crank at all but everything lit up fine. Waited about 10 seconds and tried again and it started. Problem didn't show itself again until today, Went to start it after driving to Home Depot and nothing. Waited a few seconds, everything lit back up (eventually) tried to crank nothing. Waited 15 more seconds nothing. Waited 30 ish more seconds and it started no problem. I think I heard one click maybe during the ordeal.
Watch/Learn:
Old Sep 9, 2023 | 05:49 PM
echopark's Avatar
if you “actually read” what I said I replied I’ll do what he recommended and report back.
Slingbladenade
Dec 6, 2022 04:20 PM
Humm3r
Apr 5, 2021 01:21 PM
Big_A
Aug 15, 2015 01:20 AM
jchummer
Dec 28, 2012 06:08 PM
franco
Jun 26, 2008 12:03 AM
