Whining sound
Old Jul 16, 2023 | 08:51 AM
NFS's Avatar
NFS
Default Whining sound
Hey folks, last week I went to the beach and I had to put 4wheel lock down because of the thick sand . But when I drive I hear a whiny noise coming from under. It only happen when I put it in 4lock down and only when like I press on the gas and moves . What can be the cause of this? And how can I make that whinny noise goes away?
Old Jul 17, 2023 | 01:26 PM
NFS's Avatar
NFS
anyone?
Old Jul 17, 2023 | 02:25 PM
Low gear ratio! Lo range does in fact whine.
You do not need Lo for sand. Sand requires lower tire pressure (I run like 12-14PSI Front and 11PSI rear) and a bit of momentum. If you do not have access to getting quickly aired back up for street travel, at least take it down the mid 20s as it will help a bunch.
Old Jul 17, 2023 | 04:36 PM
NFS's Avatar
NFS
okay so I am not crazy l. And the beaches here are like 15 inch sand. When u go on it using other gear options I get stuck so I have to put it at lo for me to move freely and I don’t like plan for it to put lower pressure all the sudden I be like okay let’s go to the beach and then I put it at that
Old Jul 18, 2023 | 08:34 AM
Put it in 4Hi Lock, turn OFF the Traction Control, lower tire PSI and let it rip.
The dunes here are a few hundred feet deep. The old 07 near new.
Old Jul 18, 2023 | 09:09 AM
NFS's Avatar
NFS
oooo I should def try that thank you
StevieDay
Jun 20, 2016 12:01 PM
hulkh3
Sep 12, 2012 08:02 AM
rolltide1
Jun 8, 2011 11:03 AM
cheyenne95129
Dec 4, 2008 03:31 AM
mliebs8
May 30, 2007 06:42 PM
