Whining sound
Hey folks, last week I went to the beach and I had to put 4wheel lock down because of the thick sand . But when I drive I hear a whiny noise coming from under. It only happen when I put it in 4lock down and only when like I press on the gas and moves . What can be the cause of this? And how can I make that whinny noise goes away?
Originally Posted by NFS
(Post 401986)
anyone? |
Low gear ratio! Lo range does in fact whine.
You do not need Lo for sand. Sand requires lower tire pressure (I run like 12-14PSI Front and 11PSI rear) and a bit of momentum. If you do not have access to getting quickly aired back up for street travel, at least take it down the mid 20s as it will help a bunch. |
(Post 402028)
Put it in 4Hi Lock, turn OFF the Traction Control, lower tire PSI and let it rip.
The dunes here are a few hundred feet deep. :D The old 07 near new. https://cimg8.ibsrv.net/gimg/www.hum...57d9330b9c.jpg |
(Post 402052)
The dunes here are a few hundred feet deep. :D The old 07 near new. https://cimg8.ibsrv.net/gimg/www.hum...57d9330b9c.jpg oooo I should def try that thank you |
