UPDATE: Front-end Rattle...Any Suggestions?
Old Jun 18, 2007 | 04:37 PM
  #31
hummernewby's Avatar
Default RE: Front-end Rattle...Any Suggestions?
LOL HummBob I love the Gremlin!
Old Jun 18, 2007 | 04:40 PM
  #32
Steve, Only issue with that is I've never put mine in the 4wheel drive mode.
It's been mainly city/highway driving right now. hmmmm it's a thought though.
Old Jun 20, 2007 | 06:36 PM
  #33
SteveO's Avatar
Update...problem still there!!! Driving home from work today I did notice the clicking in the foot pedal and steeringwheel.
Steve
Old Jun 20, 2007 | 07:37 PM
  #34
Hot here in Texas today and I could hear it everwhere I went. I just have to find the time to take it in now. Never enough hours in the day it seems.
Old Jun 22, 2007 | 07:49 PM
  #35
HUMMER DRIVER's Avatar
Wow..... I was driving my 07H3 today and noticed some light thumps, didn't feel anything in the pedals that I recall but I did hear the noise several times, mostly when the road got a little rough. Sounds like it is coming from down under the firewall near my steering column and pedals. It doesn't sound like it's in the cab though. I was wondering if the recent trip to Moab knocked something out of kilt.
Never noticed this before and I certainly would have as it's hard not to notice it when it does it. Just rolled over 10K miles.
Old Jun 24, 2007 | 06:44 PM
  #36
Ghostrider's Avatar
Check your tow rings. Mine sounded like this for the first few months I owned it. When it comes from the factory, they don't tighten them. I went out to the tow rings, gave the bolts a few turns...problems solved. If they are loose enough that you can move them without a decent amount of force, its too lose and it'll rattle when you go over a bump. They are attached directly to the frame so when it bangs, itrattles the whole car and things that are touching the body/frame...like the steering wheel and gas pedal. All 3 of mine are tightened down so that if i need to pull it out, you really have to pull on em hard. There is a little compression nut in the middle that eventually compresses and needs to be re-tightened. As it warmed up this summer, I heard the rattle return so I had to tighten them a few times.
Might not be all the problems for everybody but I would say a significant amount of reports will be fixed by checking your rings.
Old Jun 25, 2007 | 10:38 AM
  #37
H3PR's Avatar
Hello everyone ! I'm new to the forum....... I'm now the owner of an 07' H3 with the same problems most of you have described. The problem started with less than 800 miles. Interesting enough, I drove an 06" H3 for 11 months (17, 800 miles) with no problems.....Anyway, I just took my 07' to the dealer and the service rep. knew exatcly the problem I was reporting. The replacement part will take few weeks before arrival. The heat definitively agravates the problem(ratle), and I may add that the ratle is driving me crazy [:@]. You all are the greatest. Great communication ! I'll stay tuned.......
Old Jun 25, 2007 | 01:10 PM
  #38
DUXBAK's Avatar
Great thread to read on front-end rattle . . . I bought an '07 in early May and now have 2250 miles on it and just started to notice the rattle in the pedals in the past week or so. Took it to the dealership this morning. Service manager indicated he had 4 other '07's in last week with similar symptoms. He went on to tell me he was not sure of the cause and would have to defer to his specialist on what the "fix" would require (will likely get the call this afternoon on what the fix will entail). From all the threads it sounds like after the usual checking for loose parts and fittings (or missing bolts in one case) they will need to check the lowersteering component as suggested in threads above -- I will be calling the dealership shortly to share with them what I have read and will print a copy off for them to review. The dealership and service department have been good to work with over the past couple of years and am confident they will stay after it to make sure it gets fixed right.
Ironically, Ihad a 2006 H3 and had a lot of problems with it including head replacement. After 16 warranty visits to the dealership over the course of 1.5 years on the 2006 H3, I was ready tothrow in the towel and go back todriving aToyota when they made me a decent offer totrade up for a 2007 model. I hesitated greatly trading up for a 2007 H3 andhoped when I did I would beleaving the many problems I had with the 2006 behind . . . hope I do not come to regret the trade for the 2007 H3!!
Keep the threads coming in around the U.S. on what dealerships are doing to cure the rattles -- I'd like to get this fixed and hopefully start enjoying avehicle with no problems!!!
DUXBAK . . . .
Old Jun 25, 2007 | 10:42 PM
  #39
H3PR's Avatar
Interesting ! My 06' H3 was a late 06' production and within 17, 800 miles/11 months of use was all good. I hope my 07' "dispite the ratle pedal drive my cracy problem" would be the same.......a good truck !
Old Jun 26, 2007 | 10:43 AM
  #40
dmb7280's Avatar
quick update:my new (old design) replacementsteering shaft started rattling all the same again over the weekend just as bad as before. just wanted to share the news incase any service depts try to push off any non-redesigns. its not worth the time and effort until the new ones come (assuming they actually correct the problem). also, called sewell about it as well and their still waiting for the new part. given, this is the least of my worries at this point, but i wanted to share.
lil d
