sheathing on side of Hummer 3Gas tank?
Old Aug 6, 2021 | 07:04 PM
Scrambler's Avatar
That's the same I posted above. Yes it could work, how to keep it secure, is the question? It has adhesive backing, yet not tested in a wind tunnel. Find a way to secure it to the tank, or it will be flapping around like a skirt in the wind.
Still has plastic studs sticking out where the old one mounted to. looks like the push clips broke off i guess. Still has material backing from the aluminum piece stuck to tank, I guess ill try mounting the adhesive piece to that and secure with new clips. The old piece mustve took alot of heat because it was in rough shape.
Old Aug 7, 2021 | 10:57 AM
Starlock washers M8X1. 25, 25 O. D.,:>>>>> 10009923
Old Aug 7, 2021 | 11:24 AM
Scrambler's Avatar
thanks
Old Aug 9, 2021 | 11:13 AM
MOVED.
You posted this in the WRONG Section. READ before you POST anything.
It says at the top "Do NOT post vehicle questions in this section" and if you read that it would tell you that the HF Help & Suggestion Center is for questions regarding How To Use Forum Features, got nothing to do with any vehicle.
All questions about H3s goes in the............................................... .. that's right...........................................H3 section.
davidwilliams
Jan 14, 2017 01:04 PM
hollandpj
May 1, 2009 12:24 AM
azz7772
Nov 12, 2007 07:23 PM
HummerGuy
Oct 30, 2007 06:06 PM
HummerGuy
Jun 1, 2007 09:30 PM
