sheathing on side of Hummer 3Gas tank?
Old Aug 5, 2021 | 11:50 AM
Scrambler's Avatar
Default sheathing on side of Hummer 3Gas tank?
Piece of aluminum like metal fell off side of gas tank and was laying on top of differential. Looks like material is still on the side of the gas tank that's behind the aluminum/metal piece.
Does anyone know if this is safe to leave off since Im not doing any 4 wd? Thanks
Old Aug 5, 2021 | 05:27 PM
Heat shield to prevent the exhaust system from heating up the fuel in the tank. I wouldn't drive without it.
Old Aug 5, 2021 | 07:11 PM
Scrambler's Avatar
Thanks, looks like I have some work to do...
Old Aug 5, 2021 | 07:18 PM
Scrambler's Avatar
Would you know where to find one? I googled it and cant find anything from hummer 3 gas tank heat shield except for a GM part that fits the picture but is not a match for vehicle.
Old Aug 5, 2021 | 08:00 PM
Post a pic of the heat shield intact for further advice.
Old Aug 5, 2021 | 08:26 PM
Scrambler's Avatar
ill grab pic tommarow of side of tank where it mounts
Old Aug 6, 2021 | 12:51 PM
Scrambler's Avatar
this is all i could find about it. Its 9 and 10 im missing.
I cant find this shield anywhere and on this site, only shows it coming with the gas tank.
https://nemigaparts.com/cat_spares/e...n/03/tn03-101/
Old Aug 6, 2021 | 03:33 PM
That don't look like your tank.
The entire shield is missing? If so find a way to make a
Aluminized Heat Barrier Aluminized Heat Barrier
that won't blow away, nor get damaged by the driveshaft. Think of the concept with exhaust heat shields mounted to the floor underneath. The tank is plastic, yet the shield is metal, connect a sheet of aluminum to the shield up to the floor, or wrap the side of the tank if it will stay put?
Old Aug 6, 2021 | 04:06 PM
Scrambler's Avatar
The entire shield is missing? If so find a way to make a Aluminized Heat Barrier that won't blow away, nor get damaged by the driveshaft. Think of the concept with exhaust heat shields mounted to the floor underneath. The tank is plastic, yet the shield is metal, connect a sheet of aluminum to the shield up to the floor, or wrap the side of the tank if it will stay put?
Do you think something like this would work?
Amazon Amazon
Old Aug 6, 2021 | 06:09 PM
https://www.amazon.com/Thermo-Tec-13...CJ500SNQ4N0VGS
That's the same I posted above. Yes it could work, how to keep it secure, is the question? It has adhesive backing, yet not tested in a wind tunnel. Find a way to secure it to the tank, or it will be flapping around like a skirt in the wind.
