Read If Your H3 Radiator Has Cracked or Leaked
Old May 12, 2012 | 08:33 AM
  #201
BlueH3's Avatar
Originally Posted by singlecabboy
I didn't find out about this forum till I was searching how to fix a front turn signal bulb.Low and behold last month I shelled out $1000.00 for a cracked radiator in my 2006 H3 with 110,000 miles on it.Not at a dealership Any recource on that ? I think I already know the answer.
Best you can do is do what I did on another vehicle is first call GM Customer service, see what they say get address write letter saying common problem for that year etc...many failures docmented etc, and see if you can get some reinbusement. Makes it more difficult to get money back since you did not visit a GM dealer to fix.
Old May 13, 2012 | 04:49 PM
  #202
Mr. Big's Avatar
Originally Posted by 06H3andME
2006 Models are cracking as well, mine just did the exact same thing. 2006 H3, I ordered a replacement radiator from radiatorexpress.com ($186.00 included shipping). Put it in myself...and we'll see how it goes.
I took my 2006 H3 Hummer into the dealer to replace the APP due to intermittent Traction/Reduced Power errors over the past 3 years, and the dealer advised me that my radiator was cracked. It has an 8 inch crack in the plastic housing in the same location of my radiator (top plastic houseing right side). The dealer never mentioned anything about this being an issue, but this blog has enlighted me. I cleaned the surface and epoxied over the crack to hold me until I argue this issue with GM.
Old May 13, 2012 | 06:05 PM
  #203
drtom's Avatar
Banned
Default epoxy can be cured
and you can make a long term fix by adding another layer of the goo and embedding some screen wire mesh in it,maybe one more layer later. i did it on a probe and it was good YEARS later when sold.
epox alone will crak. oh fiberglass mesh is good 2.
Old May 14, 2012 | 09:36 PM
  #204
rsc's Avatar
rsc
Yeah, thats what I did too. Lasted all of a day before leaking past the repair. Best bet is to drive it until you are fed up with the leak and refilling the tank. Then have it replaced. It will drive just fine dripping a little fluid for now.
Old May 15, 2012 | 12:43 AM
  #205
drtom's Avatar
Banned
Default proper prep!
u gotta sand it good or better yet sand blast then epoxy.
mine never failed
Old Jun 24, 2012 | 10:24 PM
  #206
SoccerDad's Avatar
Default Bummer
Joined the cracked club today.
06 H3 auto only 38k
no extended & in 06 it was only 5y/50k
I'll get with dealer tomorrow & post again.
As a mechanical engineer, this is a design flaw.
Exact same top cracks as pictured in prior posts.
Old Jun 24, 2012 | 10:54 PM
  #207
06HummerCO's Avatar
Default Add one more to the list!
Good evening, well just joined the forums and have to say, I'm joining the many on here with a cracked radiator. Found it to tonight.
Old Jun 27, 2012 | 01:48 AM
  #208
juicebox123's Avatar
Goodness. I paid $300 for my radiator.
Old Jul 4, 2012 | 12:18 PM
  #209
craigm's Avatar
I just traded my H3 for a H3T and I had to replace my radiator in the H3 also. Dealer charged me $800. Sounds like GM needs to step up to the plate on this one.
Old Jul 5, 2012 | 08:42 AM
  #210
Mr. Big's Avatar
GM failed to address the cracked radiator issue. I ended up taking it to a local radiator shop that replaced the radiator and hoses for under $400 with aftermarket brand; less than 1/2 of the dealer's quote for OEM; which, quite frankly, is a piece of $%#&. The shop had to remove the grill to remove the radiator and the left front tire and wheel well cover to access the lower hose. I'm disgusted with GM over their failure to acknowledge and be culpable for their design flaw.
