Programming TPMS
Old Mar 15, 2026 | 11:55 AM
JeffBecky's Avatar
Default Programming TPMS
Had the low tire light on and SERV TPMS on the dash. Replaced the TPMS all 4. When I went to program them to the vehicle the horn wouldn?t honk at any wheel. I did have the vehicle in learn mode. I bought a different BCM and had it cloned also bought a different BCM antenna. Now when I program the TPMS to the vehicle it honks at every wheel. Low tire light is still on. I?ve drove it for over 300 miles and light still on. I did a live data on it with my scanner. It shows the tire pressures on each wheel bouncing around from 12lbs up to 212lbs. It will stay on a number for about 3 seconds and then change. Doesn?t matter if I?m driving it or just sitting at the house. The numbers just bounce around. They have done this with 2 different sets of TPMS. Does anyone have any ideas on why?
Old Mar 15, 2026 | 07:01 PM
What MHz?
(((((((((HUMMER H3 TPMS sensors=315MHz!))))))))
Cheap sensors & relearn tool:
Old Mar 15, 2026 | 07:19 PM
JeffBecky's Avatar
Have you used these exact ones? I have that tool and I?ve tried it as well. I also have a Foxwell Scanner and I used their Foxwell TPMS. And yes I?m using the 315mhz on both sets I?ve tried. If they have worked for you I?m willing to try them.
Old Mar 16, 2026 | 04:09 PM
NMH3's Avatar
I have that tool (or one with the same model number that looks just like it but is branded as VXDAS -
Amazon Amazon
) and use it often to relearn my VDO SE10003A Redi Sensors. The VDO sensors have broad software compatibility over a large range of vehicles and come pre-configured to be re-learned in the vehicle without requiring a tool to configure the sensor.
What specific sensors are in your tires? Do they need to be programmed/configured before use?
Old Mar 16, 2026 | 04:48 PM
JeffBecky's Avatar
I?ll give them a try. The first set I bought were cheap ones and didn?t need programming. The second set were Foxwells the same as my scanner so I was able to program them with the scanner to the vehicle.
mkarns
Sep 13, 2024 10:13 AM
Gavin Costigan
Oct 6, 2023 06:59 PM
JMU13
Apr 8, 2022 06:36 PM
