Power Locks and Driver Side Window not working
Old Mar 18, 2018 | 09:21 AM
  #211
safeman7's Avatar
I had this issue for a year. Based on info in this thread, I removed the switch assembly from the door, brought it in the house overnight and wiped the inside down with a soft cloth and reinstalled it the next morning. Turns out some moisture got in either thru the window or door during heavy rains. I had the deflector above the door reshaped a bit and the problem has not reoccurred in two years.
Old Mar 18, 2018 | 03:13 PM
  #212
blazed16's Avatar
Originally Posted by gooberschnot
sorry no
Well then that was not the answer i wanted haha. New switch then i take it?
Old Mar 19, 2018 | 09:17 AM
  #213
brodiggitty's Avatar
So I tried the procedure in the video and still no luck. The aftermarket switch has a different setup with the resistors but I still gave it a shot. I am pretty sure there is something else going on perhaps with the wiring through the door by the hinges or possibly with the switch that indicates the door being close. When you first turn the car on with the doors open you can hear a clicking noise and all windows besides the driver's will operate intermittently in conjunction with the clicking noise until you shut the door. I tried it again and manually pressed the button to indicate the door closing and it shuts off again. It doesn't continue clicking once the button is released.
Old Mar 31, 2018 | 03:24 PM
  #214
blazed16's Avatar
So yesterday my passenger window switch stopped working and when you press the button on passenger side it would just buzz.and the driver side switch would not work with the passenger side anymore even though it was rolling it up before just not down.
Now i bought a new master switch for drivers side and it lights up green super happy about that but then once i plugged it in the passenger side switch now buzzes even when you dont touch the button so i had to disconnect the switch on passenger side.
The drivers switch still wont work on passenger window at all.
Whats next for me to do? Passenger switch bad? What should i check next?
Old Apr 1, 2018 | 02:08 PM
  #215
blazed16's Avatar
Changed the battery terminals to new stinger ones but made no difference.
Let me know guys on the above post
Old Apr 2, 2018 | 09:15 PM
  #216
hummer_on_fumes's Avatar
Is the buzzing coming from inside the door? It sounds like the window regulator has gone bad
Old Apr 2, 2018 | 09:20 PM
  #217
blazed16's Avatar
I pulled the switch out.
the buzzing is com8ng from the switch.
I pull the plug on it and it stops. I plug switch in the switch starts buzzing.
Old Apr 3, 2018 | 05:42 AM
  #218
maybe try plugging in a switch from one of the other passenger doors into the one that's buzzing, see if you can then roll the window down, then you'll know if it's the switch you need to replace
Old Apr 3, 2018 | 09:35 AM
  #219
Do you have a sunroof? If so, has your passenger floor carpet got wet?
Old Apr 4, 2018 | 04:56 PM
  #220
blazed16's Avatar
Rear passanger door has same plug?
I do have sunroof and did have a leak a couple months ago inside it dripped on cup holders and seats. I had the tubes cleared up and draining fine now.
