Power Lock issues
Old Jan 3, 2020 | 07:54 PM
Originally Posted by LatvjuAvs
Did all the usual voodoo stuff, rubbing cables together, turning ignition switch, honking, dried bat wings and horse urine.
Are they stingers? Using the ignition switch drains the battery. Honking annoys the neighbors and also drains the battery. Dried bat wings are used for healing the sick. Did you check to make sure the horse was healthy?
Old Jan 8, 2020 | 02:51 PM
LatvjuAvs's Avatar
Took off drivers door out of curiosity today, wanted to see if I can take out top hinge pin, no luck, need a press for that.
Meanwhile investigated connectors, unpleasant sight, a pin was broken off, multiple pins shoved green oxidation, dirt everywhere.
I have no idea what that red cable is for, need to investigate documents.
After cleaning up and putting it back together, and loosing red connection of course, unlock/lock is not working and remote is also not locking unlocking.
If red is nothing important then as Doc said, functionality will come back, will await that!
Pin restoration project will be for another day.
Old Jan 10, 2020 | 02:06 PM
LatvjuAvs's Avatar
Update.
Yes, that red cable is integral to locking unlocking, without it I can rise all other doors window, but I can't lock/unlock with switch/remote.
Red cable has power!
Also, pin on door cable harness just crumbled apart as I pulled it out.
My car is in remote garage and I have not yet hoarded all kinds of cool stuff to use as repair, so I improvised while ordered pins are on the way for permanent fix.
Grandmas hairpin works wonders!
Put it back, plugged it in, lock works just fine!
All these times in past when my lock function was lost, it was due to pin falling apart.
lostsoul77
Nov 27, 2023 09:19 AM
WR3NCHE4D
Jan 8, 2017 01:25 PM
cjmilto
Jul 24, 2014 10:07 AM
luke0405
Dec 1, 2013 08:40 PM
BMJM100
Jan 24, 2011 07:01 PM
