Please help me, my 2006 Hummer 3 will not start then will
Old Apr 29, 2019 | 09:34 PM
Originally Posted by GrampaEJ
38PSI?!?! Really, Doc?
Label on door jamb says, 30.
Yes Indeed GrampaEJ, 38psi! No more TPMS warning, and tire wear the same, from edge to edge.
Old Apr 30, 2019 | 09:52 PM
dwaller67's Avatar
How much did your insurance rate increase, after you notified them that you no longer have a theft deterrent system?
Insurance?
The real problem is the connector to the switch. Simple fix!
No, your problem was the switch. Glad you found it and fixed it! My issue was a bit more complicated.
Now that you bypassed the passlock, its just a simple pull and turn on the ignition lock cylinder.
A risk I'm willing to take in exchange for a vehicle that starts every time I turn the key.
Just don't be bragging about it to those that know where you live.
Not a topic of discussion I bring up in public but now that you mention it I will be extra careful.
I have over 30 experience years doing troubleshooting / repair to electrical equipment. Granted it has not been working on cars but the same principles apply. A BCM is nothing but a specialized PLC with inputs and outputs. The erratic behavior described by the OP could be voltage fluctuations caused by the battery, the battery terminals, water intrusion, a harness grounding out, a loose plug, a bad voltage regulator, or a dozen other things. All you can do is eliminate one problems at a time until you find the root cause.
Old Jun 9, 2019 | 04:36 PM
Gabe Weefar's Avatar
Default Dwaller67
I am having the same problem, may I ask your help? I want to bypass the passlock system and want your help in doing so. I have my car in a third world country, no insurance to worry about. I truly appreciate your help.
Originally Posted by dwaller67
My 07 H3 had many of the same problems. I bypassed the passlock system completely, replaced the battery terminals, and ran new wiring to power on the body control module. It might have been overkill but so far I have had zero more issues. It has only been a couple of weeks since the latest repairs but so far so good.
I hope you get your issues sorted out.
Old Jun 9, 2019 | 07:34 PM
Do they sell electronic contact cleaner and dielectric grease in your "third world country"?
How Passlock works ? Ricks Free Auto Repair Advice Ricks Free Auto Repair Advice | Automotive Repair Tips and How-To
Old Jun 9, 2019 | 07:42 PM
No, the problem was @ the connector.
Old Jun 9, 2019 | 08:45 PM
Default Please help me, my 2006 Hummer 3 will not start then will
Hi Dwaller67,
Old Sep 8, 2019 | 08:45 PM
Bwasougren's Avatar
Default Help
How can i rewire mine like that
Old Sep 15, 2019 | 10:29 PM
Leo Harris's Avatar
Try getting a new computer... about 150 dollars and it will have to be programmed or learned. I was starting to have weird problems and that fixed it.
https://www.yourmechanic.com/ They make housecalls.
Old Sep 16, 2019 | 11:53 AM
Ejwins's Avatar
Default How I fixed the passlock system on my 2007 H3
I recently took the passlock switch out (located to the left of the steering column) and examined it, everything looked good and clean to my surprise. I sprayed the male/female interface part with wd40 just to see if it was maybe getting stuck and put it back together. I did that about 3 months ago and I haven't had an issue since, so I'm considering it fixed. I used to have that problem at least a couple times per month so it can't be a coincidence.
Humm3r
Apr 5, 2021 01:21 PM
yellowhummerh3
May 25, 2018 05:48 AM
Synthetickiller
Dec 29, 2014 11:45 AM
TrailerQueenH3
Oct 11, 2012 11:22 AM
Harry007
Apr 25, 2011 04:56 AM
