Parasitic Drain
Old Jan 24, 2024 | 02:27 PM
Alt should put out 14+V consistently.
Not true.
Out of curiosity, I just checked my voltage, parked at idle:
12.6v resting
11.4v cranking
15.1v startup
13.6v after 4 minutes( jumped to 13.9v when I turned accessories/lights on)
12.8v after 10 minutes (with all accessories off)
My GBCM is working properly.
If you research your dic error, you will see many posts about GBCM bypass, I don't recommend!
High Output: A Look at Today’s Charging Systems
The GM regulated voltage control system can vary from 11.5 –15.5 volts. As with other systems in use today, the GM system has a fuel economy mode, which is designed to lower the charging system voltage by reducing the alternator field strength.Technicians often diagnose this mode as a faulty charging system, only to find out that the vehicle operates the same even with new parts installed. Simply applying maximum load to the vehicle’s electrical system will cause the PCM/ECM to respond, raising charging system voltage.
GM also designed this system to identify battery sulfation. In response, the PCM/ECM will command the charging system’s voltages to increase to as high as 15.5 volts, even when there’s no electrical load. Sulfation mode will typically last less than five minutes at a time, so, as the timer expires, the system will return to normal charging operation.
Old Jan 24, 2024 | 03:06 PM
Mikey13b's Avatar
Originally Posted by 650Hawk
Radio shouldn't be pulling half an Amp (500mA) when off. Stock stereo? Amp?
Yeah the radio is definitely pulling way too much. It's not stock, I installed an Android 9 inch screen unit. It was all plug and play connections apart from the acc on wire.
Old Jan 24, 2024 | 03:11 PM
Mikey13b's Avatar
Possibly green crusties inside fuse box?
Recommendation: deoxit that socket lol. Get some deoxit and spray it in each suspect fuse insert.
check ground splice pack c105 c106 located behind air box and near abs. Remove them. Clean them. Test them. Reattach them. Deoxit them.
Make certain battery and cable ends are clean, tight and have proper values. Aka 12.6v or better with truck off.
The fuse box looks good apart from being a little dusty, definitely no green stuff inside it that i can see. Yep I get 12.6v with truck off. Ill check out the ground splice packs.
Mark R
Nov 8, 2023 08:15 PM
ski.dive
Aug 12, 2019 08:33 PM
omedus
Jan 6, 2016 07:13 AM
magicmile24
Mar 16, 2014 09:31 AM
Callaway
Jun 3, 2009 03:52 PM
