P2135 Reduced power
Old Feb 5, 2025 | 02:32 AM
ojh32008's Avatar
Default P2135 Reduced power
Greetings
my h3 is now 266000 km 2008 model
this year it starts to consume my pocket ( transmission rebuild, radiator full maintenance changing thermostat and sensor, and o2 upstream sensor)
currently the subject issue is appearing more frequently every 3 days
thanks god it didn’t happened in highway
i just stop the car and remove the negative battery then it returned back to normal
i know this subject has raised many times
i saw the bulletin regarding changing the throttle sensor.
but im looking for easy repair, the spare parts are expensive, the only alternative is changing the whole throttle body from the junk yard.
any advice
Old Feb 5, 2025 | 08:33 AM
Bosch or Hitachi?
Old Feb 5, 2025 | 11:15 AM
Before you replace the TB, disconnect the electrical connector and spray both sides of the connection (TB and Connector) with CRC Electronics Cleaner. While letting it dry, inspect the wiring for the TB for compromise, like cracks, frays, rubbing...If that does not improve the condition, then replace the TB with a new AC Delco unit for your year/model.
Old Feb 6, 2025 | 02:44 AM
ojh32008's Avatar
Bosch or Hitachi?
i have no idea but i get ac delco spare
Old Feb 6, 2025 | 02:47 AM
ojh32008's Avatar
I have already cleaned both female and male connector, but not using CRC electronic cleaner
I think it was a cheap cleaner
I will re-oil my air filter and open the throttle body
To check if there is any issue happened during cleaning it one month ago
Old Feb 6, 2025 | 06:32 AM
Old Mar 19, 2025 | 11:27 AM
ojh32008's Avatar
Originally Posted by TAINTER
i founds out that my throttle needs frequent cleaning (butterfly ) in monthly basis. Engine is old but still surviving
easy job doing it in my garage and solve this issue
Old Mar 19, 2025 | 11:54 AM
What are you using to clean the Throttle Body?
Spraying something at the open end and throttle plate is not cleaning. All late model fuel injected vehicle need a TB cleaning about once every 30 - 50K miles. It is done by using ONLY TB Cleaner and best with the TB removed from the vehicle so that both sides of the TB throat and throttle plate can be cleaned of residue and grime by wiping that out/off.
Do NOT use chock/carb cleaner or any other solvent spray/brake cleaner etc.. as you will damage the TB's internal plastic parts (gears and/or levers) and cause even more erratic response or failure.
Old Mar 19, 2025 | 03:05 PM
check your PCV system
h3fish
Dec 11, 2019 06:41 PM
Jbrashers
Nov 21, 2019 09:32 AM
ski.dive
Mar 6, 2019 04:18 PM
John Brashers
Jul 11, 2018 10:01 AM
Alex Polazzo
Jul 3, 2017 12:42 PM
