Where is throttle position sensor on the H3 located?
Old Mar 5, 2019 | 02:39 PM
ski.dive's Avatar
Default Where is throttle position sensor on the H3 located?
Is the throttle position sensor on the H3 located inside the motor cover of the throttle body?
Can the H3 TPS be cleaned or replaced ?
Old Mar 5, 2019 | 08:15 PM
The TPS is not intended to be serviceable. It is located inside the TB.
Does not need to be cleaned. If the TPS goes bad you replace the TB. There are TB rebuilding services out there, but not cost efficient most of the time.
Old Mar 6, 2019 | 04:18 PM
GrampaEJ's Avatar
Are you referring to the, (2) Accelerator Pedal Position Sensor, (APP)?
Jbrashers
Nov 21, 2019 09:32 AM
John Brashers
Jul 11, 2018 10:01 AM
jcbrowns
Jun 4, 2018 10:31 PM
Alex Polazzo
Jul 3, 2017 12:42 PM
h3carlos
Dec 30, 2013 01:14 AM
