Oil leak where water pump?
Old Jul 4, 2024 | 08:23 PM
  #31
Yet, no oil leak before you went in!
Old Jul 4, 2024 | 08:25 PM
  #32
NFS's Avatar
NFS
lol you gonna drive me crazy lol yes I know your right but the spot where you mentioned I put a brand new gasket there so I guess the dye will show us where the leak and I’ll make sure to post it here to show you as well lol
Old Jul 5, 2024 | 08:34 PM
  #33
NFS's Avatar
NFS
God damn hammerz you were right!!! The leak coming from the crank shaft pully . You think it’s that gasket you told me about ? I swear I put a new one before installing it
Old Jul 5, 2024 | 08:39 PM
  #34
NFS's Avatar
NFS
does the front cover have to be removed to install that cus I knew there is a gasket that goes into the timing cove and there is one that actually goes into the crankshaft pully they both new and the most newest one is the one
I put this one https://www.partsgeek.com/kgc6qwx-hu...wqjHAetMk_IxLy
it’s not this one right ?
Old Jul 6, 2024 | 03:47 PM
  #35
did you notice if the nose of the crankshaft has a bit of a groove in it where the seal rides? if so the groove is not supposed to be there and you might need a special seal to repair that. i guess its a bit tighter on the crank.
Old Jul 6, 2024 | 10:55 PM
  #36
NFS's Avatar
NFS
Default Update
Problem fixed thanks for hummerz and everyone who helped out ! The problem was the damn front main crank seal. When I took off the pully I think for some reason it wasn’t pushed all the way in I don’t know how that happened but anyway I took it off and installed a brand new one , made sure it’s all in and put a new washer into the pully and installed everything. Went on a little drive and came back and checked with light and UV light since I have a dye In the oil and there was none and the front cover is dry. I am gonna highway test it tomorrow but I think she is finally good to go
2005H2
May 11, 2019 02:29 PM
Hummermamma
Jan 24, 2019 06:32 PM
ukpaul
Nov 19, 2011 07:26 AM
sonicsbomb
Oct 6, 2010 08:27 AM
jstdoitt21
17
Jan 31, 2008 02:25 PM
