Oil leak where water pump?
Old Jul 1, 2024 | 03:37 PM
  #21
NFS's Avatar
NFS
Sh^t happens!
Fix it Right The First Time!
yes well atleast we know a fix for this. I am still struggling with p0202 and p0302 cylinder 2 bull****
Old Jul 1, 2024 | 06:53 PM
  #22
check wiring+connectors/contacts!
Old Jul 2, 2024 | 07:52 AM
  #23
NFS's Avatar
NFS
i did maybe the problem is inside the plug it self I don’t know but it keep happening; I am thinking to cut the injector 2 plug and just solder a new one
Old Jul 2, 2024 | 08:07 AM
  #24
wpage's Avatar
Spray it down good with contact cleaner. Probaly have some carbon build up causing a open circuit.
Old Jul 2, 2024 | 09:05 AM
  #25
NFS's Avatar
NFS
I sprayed it to clean it but it still does it every once in a while like yesterday it started fine u drove jt turned it off turned it back in at the gas station it gave me the code and engine was like sounding like you know a misfire happening liek idle roughly and such. Kinda wiggled the wires a little and turn off and start again and it ran fine so I don’t know maybe actual wire in the actual plug is like not making a full connection I don’t know but it only injector 2 circuit open and cylinder 2 misfire cus if that
Old Jul 4, 2024 | 06:42 PM
  #26
NFS's Avatar
NFS
hmm so I did that but still oil coming from somewhere ….
Old Jul 4, 2024 | 06:59 PM
  #27
NFS's Avatar
NFS
i changed the water pump and put new gasket and sealant around the gasket and also thread sealant for the bolts but I took it for a drive and came back and there was oil all over the front cover don’t know where I know hummerz I think told me to look at the crank pully gasket but I put a brand new one before putting it back. Wonder what else could it be! Any ideas ?
Old Jul 4, 2024 | 07:25 PM
  #28
What did you miss? PULL THE FRONT COVER AND PROPERLY SEAL THE BACKSIDE!
Old Jul 4, 2024 | 07:59 PM
  #29
NFS's Avatar
NFS
the oil is not coming from any of the sides where the seal is it’s coming from somewheee else I can’t see because I cleaned it all with carb cleaner and started the car and watched and nothing coming from there but then I go for a drive and come back and it’s oily
Old Jul 4, 2024 | 08:03 PM
  #30
NFS's Avatar
NFS
I am gonna get one of those dye tomorrow and use a UV light to detect where the leak from I’ll update soon
