No power to anything Battery and terminals fine
Old Sep 21, 2024 | 08:22 PM
Josh250's Avatar
Default No power to anything Battery and terminals fine
I have had no issues then today I get I. Turn the key and within 2 seconds everything blanked out. No power no dash lights nothing and my battery is good I checked every fuse for continuity then thought it must be the ignition switch relay, changed that out and still nothing but even if that was bad I should be able to turn on headlights etc I would think, I have no idea what else it could be if anyone can help. Please do.
Old Sep 21, 2024 | 11:36 PM
look for corrosion on both ends of your battery cables and the engine ground straps
Old Sep 22, 2024 | 01:14 PM
Happy Hummer's Avatar
Let's back up and start at the beginning.
Have you recently done any work or add ons?
Here are some thoughts....
1. Battery Internal damage
2. Ground strap too block/frame
3. Red power wire to starter
4. Maxi fuses
5. Fuse box failure
6. Starter internal short
Old Sep 23, 2024 | 09:30 AM
If you are still trying to use the Crappy Azzed OEM Battery Terminal Connectors, then they are anything but fine. First Mod to do to every H3/H3T is to replace the Battery Terminal Connectors with a quality aftermarket set like Stingers or your favorite brand.
Are we to assume you are talking about and H3? Year and Miles?
What is the voltage of your battery at rest?
loud pipes
Sep 5, 2020 07:21 AM
Douglas369
Oct 31, 2019 06:42 AM
Zeppelin
Sep 29, 2018 09:47 AM
newh2owner
Sep 7, 2017 03:51 PM
Husa4342
Apr 28, 2015 07:48 AM
