LED headlight and Foglight upgrade
Old Sep 17, 2020 | 09:09 PM
Indskys's Avatar
Default LED headlight and Foglight upgrade
What is involved with replacing standard headlight and fog lights with. LED Bulbs?
Old Sep 18, 2020 | 11:02 AM
Unplug, remove current bulb, insert new bulb, plug in.
If you are talking about LED headlights, that can be a different situation. >>>>>> Google
Old Sep 18, 2020 | 11:25 AM
Indskys's Avatar
So the fog lights have no effect on BCM?
the info I get on the web is conflicting
do the headlights require CanBus capacitor harness? To be clear I can just upgrade bulbs in fog lights But headlights require CanBus harness?
thanx
Old Sep 18, 2020 | 02:27 PM
"Bulb" is a bulb. Headlight/fog light can be an entire unit, bulb, reflector, clear cover etc.... different animals, keep your terminology consistent.
Bulbs
Headlight
Old Sep 18, 2020 | 08:02 PM
Indskys's Avatar
I will rephrase can you replace the Headlight and foglight BULBs. From OEM bulbs to LED bulbs without any issues? Is it just a simple swap out Or is there more to it?
Old Sep 19, 2020 | 07:54 AM
wfturner's Avatar
Yes, you are right.
Just don't go cheap LED bulbs and make sure you realign the headlight beam after your conversion
Check out these,
https://headlightrevolution.com/s-v-4-led-h13-bulbs/
phawk1969
Nov 15, 2018 11:37 AM
LastLineOfDefense
Feb 6, 2016 03:20 PM
parrip
Nov 1, 2015 06:56 PM
motley1987
Oct 6, 2014 06:21 PM
H3 PIlot
Jul 10, 2013 03:58 PM
