Hummer h3 misfire
Old Aug 29, 2024 | 08:50 AM
  #41
Originally Posted by beltz0826@gmail.com
Bought some seafoam spray (through throttle body) today. Will try it asap. Is there any way to check the catalytic converter?
Take apart the exhaust and look at it or get a scanner that can read the O2s and select catalytic efficiency. If you do not have a P0420, stick with the program and avoid chasing tangents.
Old Aug 29, 2024 | 10:38 AM
  #42
beltz0826@gmail.com's Avatar
Ok. Just heard good and bad things about seafoam. Guess I’ll give it a go and see what happens! Will keep everyone updated
Old Aug 29, 2024 | 02:13 PM
  #43
Possible causes for a P0118:
- Low engine coolant level
- Faulty Engine Coolant Temperature (ECT) sensor
- Faulty engine coolant thermostat
- Engine Coolant Temperature (ECT) sensor harness is open or shorted
- Engine Coolant Temperature (ECT) sensor electrical circuit poor connection
Use the above for a check list, do the easy stuff first.
Check coolant level, check the wiring to the ECT, clean the connector to the ECT with CRC Electronics Cleaner.
From your answers before, I do not see anything you have shared that indicates the T Stat is bad, so after the above and no improvement, I would suspect the ETC may be bad.
Old Aug 29, 2024 | 05:37 PM
  #44
Originally Posted by doc olds
possible causes for a p0118:
- low engine coolant level
- faulty engine coolant temperature (ect) sensor
- faulty engine coolant thermostat
- engine coolant temperature (ect) sensor harness is open or shorted
- engine coolant temperature (ect) sensor electrical circuit poor connection
use the above for a check list, do the easy stuff first.
Check coolant level, check the wiring to the ect, clean the connector to the ect with crc electronics cleaner.
from your answers before, i do not see anything you have shared that indicates the t stat is bad, so after the above and no improvement, i would suspect the etc may be bad.
Add 1 to that list>>-USER ERROR:
just the one code when i put the scanner back on it. P0305.. If i unplug the coolant sensor that code goes away and i only have p0018
Old Aug 31, 2024 | 03:11 PM
  #45
Went to do the above and wouldn’t start. Acted like alternator so I removed it and had it tested and it passed. Idle pulley mount was broke in half (which I’m guessing caused the no charge) trying to find a replacement. Will keep updated
Old Aug 31, 2024 | 06:51 PM
  #46
When you inject too much fluid without proper rpm to burn off you Hydrolocked the engine. Get a socket and a long breaker bar and rotate the crankshaft pulley to release.
Old Oct 5, 2024 | 02:12 PM
  #47
Got everything back together. Fired it up.. I heard the timing chain slapping. Looks like I’ll be doing that again.
Old Jan 27, 2025 | 03:54 PM
  #48
Ran seafoam through it. Seems to do a bit better (starts right up now) but still says misfire on cylinder 5 (check engine light flashes then stays solid). Also shakes when starting off (going down the road)
only one code shows up.. P0305
Last edited by beltz0826@gmail.com; Jan 28, 2025 at 08:10 AM. Reason: Left out info
Old Jan 28, 2025 | 08:22 AM
  #49
Check the coil pack for #5 (all the way to the rear) by swapping any other one to its spot and see if the misfire follows what was the #5 coil pack. Inspect the wiring harness and connector to #5, clean with CRC Electronics Cleaner. If the misfire follows the new location of #5, get a new coil pack to replace it
Old Jan 28, 2025 | 08:41 AM
  #50
Already did that. Still a misfire on cylinder 5. I’m guessing it’s a valve? Just seems strange that it doesn’t do it when the coolant temp sensor is unplugged
