Hummer h3 misfire
Old Aug 27, 2024 | 06:33 PM
  #21
Originally Posted by beltz0826@gmail.com
Checked once more. 0.07 and dropped to 0.06
PCM detects low voltage @ 0.06.
Old Aug 27, 2024 | 06:42 PM
  #22
beltz0826@gmail.com's Avatar
So trace wires and replace?
Old Aug 27, 2024 | 06:47 PM
  #23
Do you have 12v+ at red?
Old Aug 27, 2024 | 06:48 PM
  #24
Yes it reads correct
Old Aug 27, 2024 | 07:03 PM
  #25
Replace the failed CMP sensor.
Old Aug 27, 2024 | 09:03 PM
  #26
Waiting on parts to come in. Replacing both camshaft position sensors with ac Delco brand. The two currently installed was some cheap crap. Will keep posted
Old Aug 28, 2024 | 10:34 AM
  #27
After I install this sensor, will I need to do a “relearn”?
Old Aug 28, 2024 | 06:38 PM
  #28
Installed new sensor. Ran great until hooked coolant temp sensor up then 2 codes. Misfire on cylinder 5 and coolant temp sensor detected. The coolant sensor isn’t a doorman it is NTK
Old Aug 28, 2024 | 06:40 PM
  #29
Also the check engine light was flashing
Old Aug 28, 2024 | 06:43 PM
  #30
Isn’t a ac Delco coolant sensor***
