Hummer H3 Group 86 battery vs. Group 65
Old Nov 29, 2019 | 04:44 PM
esfop319's Avatar
Default Hummer H3 Group 86 battery vs. Group 65
When I purchased my 2007 Hummer H3, I noticed that I have a Group 65 battery in it. I researched and found that the Hummer calls for a Group 86. My question is, will it make that much of a difference if I don't change it? And, if I don't, how will it affect the vehicle. Thanks in advance.
Old Nov 30, 2019 | 08:54 AM
65 is physically larger and may have more cranking amps.
As long as the battery is secure in the box I see no issues.
Old Nov 30, 2019 | 01:49 PM
wpage's Avatar
The metal pan under the plastic battery enclosure is big enough to hold a larger unit.
Upgrading to a larger battery is no big deal.
Old Nov 30, 2019 | 03:49 PM
x2, the heat from the engine will overheat the battery, if left unprotected. 65 is 3" longer, oem box won't work.
Old Dec 1, 2019 | 10:25 AM
esfop319's Avatar
Thank you, all.
Old Dec 1, 2019 | 01:29 PM
wpage's Avatar
Welcome bro. Not to worry about expansion....
The stock set up is all eye candy.
Old Dec 1, 2019 | 02:33 PM
Research: "heat deterioration"
Many batteries mounted under the hood will have a heat barrier to protect the battery from excessive heat. Make sure that barrier is still in place.
curleymon
Jan 19, 2019 10:49 AM
scabello
Nov 12, 2017 06:53 PM
vinny
Oct 19, 2012 05:59 AM
Theuofmiami
Nov 13, 2010 09:27 PM
kdec19
21
Nov 3, 2008 10:10 AM
