Hummer h3 cold start problem
Old Feb 11, 2020 | 08:53 PM
  #31
rockhound's Avatar
sorry no I gave you the wrong name. The IAT intake air temperature sensor is what i meant.
I believe on the hummer it is part of the MAF sensor
The IAT sensor is responsible for measuring the air temperature and density to achieve the optimal air/fuel mixture for any condition.
Depending on the time of year, IAT sensor issues can be a real problem. When it is cold outside, it may be more difficult for your H3’s engine to start. This is due to a lean condition that’s more noticeable when the air temperature is lower.
Old Feb 11, 2020 | 08:55 PM
  #32
NFS's Avatar
NFS
i took off and cleaned the Maf sensor and put it back but I never replaced the maf sensor. Are u saying to replace
it ?
Old Feb 12, 2020 | 08:02 AM
  #33
NFS's Avatar
NFS
Try swapping relays 66 with 72 and 77 & 78 with 87 & 88
for some reason the wife said the car is worse after swaping relays.. where can I buy those relays and what is the part number I am willing to replace all of them and give it a shot. Are all of them the same ?
Old Feb 12, 2020 | 09:10 AM
  #34
rockhound's Avatar
The MAF sensor could be your issue. Being that you say it is showing up when its colder that leads to the IAT part of the MAF.
The MAF sensor has a total of 5 wires. Three of them are dedicated to the MAF part and the other 2 are dedicated to the IAT Sensor part.
You seem to be throwing parts the problem. This one is the one part that is actually affected by temperature.
I know mine had an issue starting in the cold the other day, but it was -22 degrees,
Old Feb 12, 2020 | 09:23 AM
  #35
NFS's Avatar
NFS
okay I will change the maf sensor, can you please tell me why the car got worse when the relays swapped or is it just a Coincidence?
Old Feb 12, 2020 | 09:56 AM
  #36
rockhound's Avatar
i have no idea about the relays,
Old Feb 12, 2020 | 10:55 AM
  #37
NFS's Avatar
NFS
well the relays are cheap so I will replace them and also replace the maf sensor. I ordered them they should arrive in few days then I’ll put them in and see how it act . Ill
update in few days
Old Feb 12, 2020 | 12:30 PM
  #38
if you swapped your relays and the problem changed which it has because it got worse then that means you have bad relays or corrosion in the fuse box.
Old Feb 12, 2020 | 12:35 PM
  #39
NFS's Avatar
NFS
I am not sure I’ll check the box and make sure no corrosion before I install the new ones
Old Feb 12, 2020 | 12:37 PM
  #40
try the relays first before changing out the MAF sensor as it is wise to go from the cheapest option to the most expensive when troubleshooting issues.
