Hummer h3 cold start problem
Old Feb 9, 2020 | 03:29 PM
  #21
rockhound's Avatar
40 degrees is not a cold day, im starting mine in below zero weather
Old Feb 9, 2020 | 03:31 PM
  #22
NFS's Avatar
NFS
Originally Posted by rockhound
you should post a list of what you have done
crank shaft sensor
new battery
battery terminals
new fuel pump
starter
coils and sparks
ignition switch
every mechanic tries soemtning and still no luck
the last mechanic said it was the after market security system and it wasn’t
Old Feb 9, 2020 | 03:35 PM
  #23
NFS's Avatar
NFS
Upload to YT then copy/paste your video url in your next reply...
https://www.youtube.com/watch?v=9w-gQAwS2uc
here is a video of me trying to start it
Old Feb 9, 2020 | 03:36 PM
  #24
NFS's Avatar
NFS
Originally Posted by Xudolucid
Both my H3's have the done the same during cold days. I've never found a solution. I've replace water pumps and sensor and nothing works yet. The only thing that helps the car start. Is when I turn the engine on, I put my foot of accelerator pedal keeping the rpm above 1 and under 2 for about 30 sec to 1 min. My theory is that since the engine and most of the car are made out of metal. During cold days and nights, the metal tends to freeze in place causing the engine to struggle to turn on. Hope this helps, I'll update if I find a solution
but it wasn’t doing that before I had this car I. MN and it was below zero and it would start now all the sudden it start to act up
Old Feb 9, 2020 | 04:08 PM
  #25
Originally Posted by NFS
https://youtu.be/hwiRxgtXFpk
Try swapping relays 66 with 72 and 77 & 78 with 87 & 88
Old Feb 9, 2020 | 05:21 PM
  #26
NFS's Avatar
NFS
those relays under the hood? And it’s tough to know if it’s the problem or not cus sometimes it crank and start right away and sometimes it crank and it doesn’t start but I’ll swap them and drive the car for like a week and see if it still does it . Thank you a lot for ur help I’ll give it a try and update you soon
Old Feb 9, 2020 | 06:27 PM
  #27
rockhound's Avatar
you have checked quite a few things, but there are other sensors that can cause your issue
It still sounds like you are not getting fuel to me. when you crank it like that do you have a strong smell of fuel coming out the tailpipe? If not you are probably still not getting fuel. if you do then you are flooding it. Try starting it with the pedal at wide open throttle see if it starts
voltage regulator
alternator
fuel pressure regulator
throttle position sensor
ambient air temperature sensor
Old Feb 11, 2020 | 07:24 PM
  #28
NFS's Avatar
NFS
voltage regulator
alternator
i swapped the relays it’s hard to till Becuase the weather is warmer so I will have to wait and see. The alternator is good Becuase I checked it and it’s not that old , throttle position sensor changed already .
how can I check the voltage regulator
and the fuel pressure regulator Becuase the mechanics said I am getting good fuel pressure.
And where is that ambition air temperature sensor and how to check that?
Old Feb 11, 2020 | 08:05 PM
  #29
Sensor is located behind the front grill. To check, compare ambient temperature to your rear view mirror:
Old Feb 11, 2020 | 08:27 PM
  #30
NFS's Avatar
NFS
the only problem is that when the mechanic took off the security system they ****ed up my rear view mirror now my rear view mirror is not getting power and also the lights inside don’t come on when I open the door...
