Heater Intake Pipe.
Old Mar 17, 2023 | 01:09 PM
Canalagator's Avatar
Default Heater Intake Pipe.
I blew a hole in my heater intake pipe, part # 12564053 and the part is discontinued. 3 different parts houses tell me the part isn't available anywhere in the country. Does anyone know if a like part from a different vehicle is workable? It's a 2006 H3. Thanks
Old Mar 17, 2023 | 03:16 PM
How did you blow a hole in the inlet pipe?
Old Mar 17, 2023 | 07:35 PM
Although it's called a heater inlet pipe, it's actually a hose that moves hot water and is situated behind the manifold, and like many radiator hoses, it split.
Old Mar 17, 2023 | 07:41 PM
Old Mar 17, 2023 | 07:44 PM
GM 12564053Pipe,Heater Inlet
Old Mar 18, 2023 | 04:38 PM
Justinh's Avatar
Is that thing metal? How much pressure do you have in the cooling system?
Can you cut it at the split can clamp on a hose?
Old Mar 18, 2023 | 06:50 PM
I believe it is metal. My mechanic removed it as it had split, and with a grinder, epoxy, and whatever else he may have used got it closed up and back in and working, I'd just like to find another alternative if it happens again. I would think another GM product should fit, if not perfectly, at least usefully, and figure someone here may know as I doubt I'm the only one who's had this problem. It's working for now, just trying to get in front of next time.
Old Mar 18, 2023 | 06:54 PM
ou2mame's Avatar
If it's metal can't it be welded?
daniel5455
Jul 5, 2023 12:53 PM
yoH3
Mar 15, 2023 05:43 PM
JAC-H2
May 6, 2020 07:47 AM
Infantry11b248h
Jan 2, 2020 06:58 PM
fishaholic
Mar 27, 2007 01:27 PM
