H3 will not turn over
Old Oct 23, 2021 | 11:22 AM
burlingd's Avatar
Default H3 will not turn over
2006 h3 will not turn over. New battery clean tight cables. Replaced complete fuse box under hood all relays/fuses checked. Accessories all work. Any ideas?
Old Oct 23, 2021 | 06:09 PM
Old Oct 26, 2021 | 10:46 AM
Welcome.
MOVED to the H3 Section where ALL H3 questions go. Please read before you post anything anywhere as the H3 FAQ section states in a sticky thread Do not post in this section as just because you thought up some question does NOT make it an FAQ.
Just because you got a new battery off the shelf from some auto store does not mean it is fully charged and ready to go. What is the resting voltage?
Are you still using the Crappy Azzed OEM battery Terminal Connectors? If so, impossible to have a tight connection. First Mod to do to every H3/H3T is to replace those junk connectors with a quality aftermarket set like Stingers or your favorite brand.
Assuming you have 12.6V+ resting Battery Volts, have you tried to jump the solenoid posts with key in run position or checked for voltage there?
Last, you said you replaced the fuse block so my next question is do you have all other power to the truck? There is a trick to correctly connecting the fuse block to the harness connectors in the tray below and when you do not get that right, you will have issues.
madmayo
Feb 8, 2015 07:37 AM
Terds
Apr 7, 2013 12:49 PM
tuffenuff
Aug 5, 2011 08:28 AM
Andreas_Sweden
Jun 27, 2011 05:09 AM
SafariHummerH2
Jun 8, 2008 07:55 PM
