H3 running hotter than usual
Old Jun 23, 2023 | 09:33 PM
  #41
Nonibot's Avatar
Your original post: "235°F"
Yes and that's what I'm saying, this problem started randomly and we haven't figured out a reason yet so can the head gasket just leak and cause the temperatures to rise out of the blue?
Old Jun 24, 2023 | 07:34 AM
  #42
Disel's Avatar
Originally Posted by Nonibot
i dont trust any other brands here in the middle east, hence why I've stuck with ACD till now
I moved the thermostat to the top and put it from Toyota. Everything is fine. Just changed the radiator and also put the radiator cap from Toyota. Haven't had any problems for several years now. But tomorrow I want to start work on installing an additional radiator. I think that there is not enough coolant for such an engine.
Old Jun 24, 2023 | 07:36 AM
  #43
Disel's Avatar
Of course there may be a problem due to the gasket. Also check the radiator cap.
Old Jun 24, 2023 | 08:05 AM
  #44
Nonibot's Avatar
what exactly was the problem you were facing earlier? Temp at 3/4 or proper heatups?
Old Jun 24, 2023 | 08:06 AM
  #45
Nonibot's Avatar
That's what I'm asking, how can the gasket go bad randomly without ever heating up before this problem began? And also, i never lost and still dont lose any coolant
Old Jun 24, 2023 | 11:10 AM
  #46
Disel's Avatar
overheating in the mountains. In traffic jams high temperature with air conditioning
Old Jun 24, 2023 | 11:11 AM
  #47
Disel's Avatar
check the temperature of the radiator. and everything will become clear
Old Jun 24, 2023 | 08:24 PM
  #48
Under 220° not likely, @225° thermostat should be wide open. Coolant temp above 225° is the breaking point. This extreme heat along with the temperature variances between the engine block and head gasket can stress the gasket to the point of rupture.
Old Jun 24, 2023 | 08:39 PM
  #49
It only takes 1 overheat! Just remove the thermostat & recheck.
Old Jun 24, 2023 | 08:41 PM
  #50
Nonibot's Avatar
of course, but I'm talking about beforee the first overheat 😅
