H3 Horn Chirp at lock not working
Old Apr 2, 2021 | 01:12 PM
  #21
Nonibot's Avatar
Hahaha the type of horn really doesn't bother me so I'm okay with the factory one too (two factory one's installed on mine by the previous owner)
Old Apr 2, 2021 | 01:20 PM
  #22
Nonibot's Avatar
Just for the heck of it disconnect one horn. Maybe the amp draw from the extra horn is too much for the 'chirp' signal. Possibly the steering wheel button works because that's going thru a different circuit that can handle the extra load.
Okay so I did this as follows;
Disconnected the left one first and checked if it's working from the inside - it did but no chirp still.
Disconnected the second one and did the same - works from the inside but not the chirp.
Basically both are working but no chirp regardless.
Pictures of the setup attached.
Left to right to get an idea of the connection
Left factory horn with OE harness visible at the bottom
OE harness and workaround done to connect both
Right additional horn
Old Apr 2, 2021 | 05:30 PM
  #23
Test the theft deterrent system.
Jump into the drivers seat with all doors closed.
Use the rke to lock the doors.
Look at the cluster, security indicator should be flashing(pic below).
Manually unlock the drivers door and open.
Does the horn sound?
Old Apr 2, 2021 | 05:37 PM
  #24
Nonibot's Avatar
Jump into the drivers seat with all doors closed, use the rke to lock the doors.
I'm sure that works. As I mentioned that my driver door lock actuator is bad and due for replacement soon, I have to use the key to lock and unlock the door whilst the rest of the doors lock with the rke. Point being; if I mistakenly open the driver door whilst the rest of the doors are locked, the horn goes off to alarm, so I'm pretty sure it'll work the same if I do it from the inside.
Old Apr 2, 2021 | 05:51 PM
  #25
I posted the diagram above(door switches, not actuators), With doors closed, rke lock, does the security light flash?
Old Apr 3, 2021 | 07:49 AM
  #26
Nonibot's Avatar
I mentioned the actuators just to explain why I could open the driver door from the outside whilst all other doors are locked and cause the horn to go off as an alarm.
So anyway I did as you asked and yes, the security indicator flashes and unlocking manually and opening the door triggers the alarm/horn
Old Apr 3, 2021 | 03:56 PM
  #27
Snow melted and 50's today, checked my factory horn, it's a klaxon. I set to rfa-2. Horn sounds when lock button is pressed on the rke. It also sounds with the drivers door open when the lock button is pressed on the rke.
You have an issue with your aftermarket horns or bcm.
OE horn:
Old Apr 3, 2021 | 04:08 PM
  #28
Nonibot's Avatar
OE horn:
Even the South African/European/Middle Eastern models have the same Klaxon horn?
Strange that it works in every situation but just not for the chirp
Old Apr 3, 2021 | 04:53 PM
  #29
Port Elizabeth, South Africa assembly plant, would not go out and buy horns stamped "HORN", besides the OE wires to the horn is green & black. Maybe Doc Olds or Broken Halo could test RFA-2 with AM horns?
Old Apr 3, 2021 | 04:59 PM
  #30
Nonibot's Avatar
LMAO yeah, the black wire is still attached to the OE harness and the green wire is out and rewired and runs to both horns. There is some taping on the black one too, not sure what's really happening there.
I'm not electrically inclined. AT ALL. 😂
