H3 Horn Chirp at lock not working
Old Apr 1, 2021 | 01:50 AM
Nonibot's Avatar
Are you using an oe 10335583 rke?
It's the original one. Back of the fob says Delphi 10335582-88.
It also works to change the RFA settings so I dont reckon the rke is the issue?
Old Apr 1, 2021 | 01:55 AM
Nonibot's Avatar
Oh wait I've just thought of something. Does it have anything to do with the driver door actuator? My actuator is dead and I have to manually lock the driver door with the key. The rest of the doors lock with the fob as they should. I also think my tail gate actuator is dead but I'm yet to confirm that.
Do you think that could affect it? I mean I have locked the driver door first with the key and then used the fob to lock the rest with no chirp, but I'm just wondering.
Old Apr 1, 2021 | 08:34 AM
gpcalero's Avatar
That might affect it. Replace them and see if it works.
Old Apr 1, 2021 | 10:00 AM
Would have been helpful from the start. Pretty sure the BCM has to receive confirmation from the actuator (position) and door closed sensors to command the chirp.
Old Apr 1, 2021 | 10:20 AM
Nonibot's Avatar
Yeah possibly, it only clicked now that it could be a reason. I'll replace and update soon.
Thanks a bunch guys! I'll update soon.
Old Apr 1, 2021 | 01:22 PM
Nonibot's Avatar
Soooo I just made another discovery.
I noticed some weird taped wires going in front of the radiator while I was trying to pull my grille out, and at a closer look I found that there are two horns directly connected.The main harness was out but the wiring from it was used to run both horns.
Both horns look factory but I think the H3s came with a single horn and the previous owner must have coupled another factory horn for some reason coz it doesnt seem any louder than one's I've heard otherwise.
My horn works just fine from the steering but I'm now pretty certain that this workaround has something to do with the missing chirp.
I guess a trip to an auto electrician is due to really know what's going on 😩 idk but this just makes me mad haha
Old Apr 1, 2021 | 02:49 PM
Broken Halo's Avatar
Just for the heck of it disconnect one horn. Maybe the amp draw from the extra horn is too much for the 'chirp' signal. Possibly the steering wheel button works because that's going thru a different circuit that can handle the extra load.
Old Apr 1, 2021 | 04:44 PM
Old Apr 2, 2021 | 09:08 AM
I've got the PIAA 85115 LOUD SPORTS HORN SUPERIOR BASS (SET OF TWO) - 330hz & 400hz set on my 09 Alpha and they beep twice, but I also have an aftermarket remote entry/start.
The factory H3 horn SUCKS! Sound like a pregnant Goat moaning if you are close enough to hear it.
Old Apr 2, 2021 | 10:42 AM
^^^^^^^Exact same setup I have, (pic not updated), for alarm chirp or to give someone a gentle nudge not moving at a green light. When I'm pissed off I've got the four of these!
