H3 Horn Chirp at lock not working
Old Mar 31, 2021 | 07:49 AM
Nonibot's Avatar
Default H3 Horn Chirp at lock not working
Hi guys,
07 H3 from the Middle East. So I searched the forums and found the method to turn on different settings for the light flashes and horn chirps at locking/unlocking but it does NOT seem to be working for me.
Mine was initially set to RFA1 which I changed to RFA2 and RFA3 but the horn chirp just doesnt activate. The lights flash as usual but no horn regardless of the setting.
What am I missing?
Old Mar 31, 2021 | 09:02 AM
Welcome.
My 07 never had any horn chirp and I never wanted one. Might want to read the owner's manual.
Old Mar 31, 2021 | 09:29 AM
Nonibot's Avatar
Welcome.
I did look at the manual and I did the thingi to activate it as well, but didn't work. I can switch between options between RFA1 to RFA4 but only the lights flash with no chirp
Old Mar 31, 2021 | 09:45 AM
Does the horn work?
Once the desired mode is shown on the DIC display, briefly press the reset stem to set your choice. The DIC display will then clear.
Old Mar 31, 2021 | 10:05 AM
Nonibot's Avatar
Does the horn work?
The horn works, and I've already dont these settings as I mentioned but still no chirp. Currently set at RFA3 but just flashes.
do you reckon I remove disconnect the battery and touch terminals perhaps?
Old Mar 31, 2021 | 10:35 AM
Disconnecting and touching battery terminals together does NOTHING for GM vehicles. It's a BS interweb thing. An H3 stores the last 300 ignition cycles power or no power, touching terminals together, dancing around a camp fire, clicking heals together.............. might make you feel like you did something, but not.
Good luck.
Old Mar 31, 2021 | 10:41 AM
Nonibot's Avatar
Good luck.
well, a lot of people with H3s have solved weird electrical issues by doing that but I've been skeptical.
I cant seem to make sense of why mine isnt chirping and I really need that.
Old Mar 31, 2021 | 12:22 PM
Press lock 2x for horn.
Old Mar 31, 2021 | 12:26 PM
Nonibot's Avatar
done that, doesn't work
Old Mar 31, 2021 | 05:12 PM
Are you using an oe 10335583 rke?
